it's the first time that I create gerber files for a pcb printing website. I'm looking to the bottom layer with a gerber view, but it doesn't seem to be mirrored... enter image description here
it's the same view as in eagle, i.e. from the top. Is this ok or not?
thanks
    \$\begingroup\$ Yeah, that's fine mate. My gerbers show the same way (bottom layer is viewed as if through the top, not from the bottom). The PCB manufacturer will take that and flip it. \$\endgroup\$
    – I. Wolfe
    Mar 6, 2015 at 17:02
Yes - it should be possible to view all the Gerbers in the stackup at once and have them line up. The PCB house will flip them according to whether they're "top" or "bottom".
See After the PCB is designed, what do I need to check in the Gerber files?
