I need to PWM my LED on STM32F3 Discovery which is on PE8. I have found code which is using PWM on PA8 and PC8 (one using TIM1) but unfortunately I can't change it to PE8.
How to do it? Or maybe you have better code to enable PWM using TIM1?
Original code:
#include "main.h" //main library to include for device drivers, peripheral drivers, etc.
void RCC_Configuration(void);
void GPIO_Configuration(void);
// Unused global variables that have to be included to ensure correct compiling */
// ###### DO NOT CHANGE ######
__IO uint32_t TimingDelay = 0; //used with the Delay function
__IO uint8_t DataReady = 0;
__IO uint32_t USBConnectTimeOut = 100;
__IO uint32_t UserButtonPressed = 0;
__IO uint8_t PrevXferComplete = 1;
int main(void)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
RCC_Configuration();
GPIO_Configuration();
TIM_TimeBaseStructure.TIM_Period = 600;
TIM_TimeBaseStructure.TIM_Prescaler = 6000-1;
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_Pulse = 600/1.2;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
TIM_OC3Init(TIM3, &TIM_OCInitStructure);
TIM_OC1Init(TIM1, &TIM_OCInitStructure);
TIM_Cmd(TIM3, ENABLE);
TIM_Cmd(TIM1, ENABLE);
TIM_CtrlPWMOutputs(TIM1, ENABLE);
while (1);
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA,ENABLE);
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
GPIO_InitTypeDef GPIO_InitStructure;
GPIOA->AFR[1] |= 6; // AF6
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 ;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIOC->AFR[1] |= 2; // AF2
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
GPIOC->AFR[1] |= 2;
GPIO_Init(GPIOC, &GPIO_InitStructure);
// Function to insert a timing delay of nTime
void Delay(__IO uint32_t nTime)
TimingDelay = nTime;
while(TimingDelay != 0);
// Function to Decrement the TimingDelay variable.
void TimingDelay_Decrement(void)
if (TimingDelay != 0x00)
TimingDelay--;
// Unused functions that have to be included to ensure correct compiling
uint32_t L3GD20_TIMEOUT_UserCallback(void)
return 0;
uint32_t LSM303DLHC_TIMEOUT_UserCallback(void)
return 0;
Edited part:
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOE,ENABLE);
GPIOE->AFR[1] |= 2; // AF2
GPIOE->AFR[1] |= 2;
GPIO_Init(GPIOE, &GPIO_InitStructure);
