This tutorial starts with programming the Ravens and Jackdaw with a Windows box. Can I do those initial steps with a Linux or OS X machine instead? If so, how? Is there any risk of bricking the hardware if I just try?
I have a USB JTAG ICE MKii clone, which is supposed to work for this.
I'm totally new to AVR, but very experienced with C/C++ programming on Linux or OS X, up to and including kernel programming.
Under Linux, you'd probably use avrdude to program them. It supports most programmers and most AVR chips. The main thing to watch out for, is that I think you need to use avr-objcopy to extract the data from the 'ELF' binary files, you can't program the 'ELF' directly with avrdude.
Random googling for avr-objcopy / avrdude commandlines comes up with this, which looks like it might work:
# create demo.bin from demo.elf
avr-objcopy -j .text -j .data -O binary demo.elf demo.bin
# program demo.bin to the 'flash' memory in an 'atmega128' chip,
# using a 'stk200' programmer connected to the 'lpt1' port on your computer
avrdude -p atmega128 -c stk200 -P lpt1 -U flash:w:demo.bin:r
| improve this answer | |
  • \$\begingroup\$ Ok. Do you know the exact avr-objcopy incantation to do that splitting? I've figured out quite a bit of the avrdude part, I think, but not what the right way of splitting the ELF files is. \$\endgroup\$ – Andrew McGregor Feb 12 '10 at 2:42
  • \$\begingroup\$ Did some random googling, above is what I found \$\endgroup\$ – davr Feb 12 '10 at 6:45
  • \$\begingroup\$ Thanks, that got me most of the way. For the record, you also have to extract the eeprom section from the elf files, and of course set the fuses right. \$\endgroup\$ – Andrew McGregor Feb 12 '10 at 8:22
  • \$\begingroup\$ Ah ok, I haven't programmed eeprom from the PC before (I've always had my software program its own eeprom), so I didn't think of that. \$\endgroup\$ – davr Feb 12 '10 at 19:16
If you're developing projects on Linux, do some searching for a good Makefile that supports avr-gcc and avrdude. You should then just have to edit the Makefile to specify your hardware and source files and you're away.
To build a binary you generally just call make, to program a device is often make program and sometimes make fuse to set the fuses on the AVR.
I've used Mfile for generating Makefiles on Windows, but it looks like they support *nix also.
Avrdude works just fine on OSX too. Just,
port install avrdude avr-gcc avr-binutils avr-gdb avr-libc
And you're ready to do everything that WinAVR does.
