I have a schematic sheet in Altium Designer 13.1 and I made an unconnected label (in the red rectangle) on purpose.
My problem is: when I compile this sheet, there is no error shown in the Compile Errors tab but I definitely have one, a "Floating Net Label" type.
Do I miss some settings here and that's why I can't see the error(s)?
Solution found: to see errors in the Compile Errors tab the following steps should be done:
  1. Compile project
  2. Open View-->Workspace Panels-->System-->Messages tab
  3. Here you can see all warnings and errors, double clicking on an item will show the speific error in the Compile Errors tab
    \$\begingroup\$ Just a comment. You can define what is an error and what is a warning or what should not be displayed at all. You can find this in Project Properties -> Connection Matrix and another tab next to it (don't remember the name right now). \$\endgroup\$
    – Tom L.
    Mar 8, 2015 at 17:31
  • \$\begingroup\$ I thought that the results of the compilation will be shown in the Compile Errors tab, but I was wrong and the results are displayed in the Messages tab, which was not visible for me. \$\endgroup\$ Mar 8, 2015 at 18:02
