I have a board which is powered by a 5V PSU. I needed to measure the current flowing into the processor for computing power. Since there was no resistor that I could find in the path from the supply to the processor, I found an inductor on the path to the processor from the supply and measured the voltage drop across the inductor(ignoring the inductance and only considering the resistance of the inductor) with a multimeter. Now since the power consumption can vary across a program's duration I wanted to measure this using an oscilloscope.
For this I connected the probe and the ground across the inductor (L18 inductor in the schematic given below) and measured the voltage. Though the idle voltage did not match the multimeter readings, the dynamic change in voltage when a program runs on the processor matched the value given by the multimeter.
SMPS schematic
But I later read in many posts that the correct way to measure the voltage across a resistor is to use two probes and the math function or use a differential probe. Later I used a differential probe to measure the voltage drop and here also I found that the idle value differs from the multimeter but the dynamic change matches the multimeter readings.
  1. What errors are there in the measurement I made by connecting the oscilloscope probe and ground across the inductor?
  2. Why didn't this cause a short and cause all the current from the voltage supply to go to the ground of the oscilloscope?
  3. Why did the dynamic change in voltage match the multimeter readings?
  4. Why are the idle voltage values different when measured by the oscilloscope (when using differential or passive probes) and the multimeter?
I was using a Tektronix MS04104 Mixed Signal Oscilloscope and the board was a pandaboard.
  • \$\begingroup\$ Are you sure your oscilloscope input isn't simply set to AC coupling mode? \$\endgroup\$ Mar 10, 2015 at 14:56
  • \$\begingroup\$ I was using DC coupling. \$\endgroup\$
    – kiran
    Mar 10, 2015 at 15:11
  • \$\begingroup\$ I'd guessed AC coupling too. The scope ground might probably mess things up but it seems to me that your device is battery power, if it isn't earth connected you are safe. \$\endgroup\$ Mar 10, 2015 at 15:23
  • \$\begingroup\$ How about some actual numbers? Inductors make a lousy resistor for precise measuring purposes- the resistance of the copper winding will increase by about +0.4% for every degree C of temperature rise, so even a modest rise can cause a fairly large error. \$\endgroup\$ Mar 10, 2015 at 15:29
  • \$\begingroup\$ What did you do with the ground leads while measuring the differential with the two probes? \$\endgroup\$
    – DerStrom8
    Mar 10, 2015 at 15:48
  1. Probably none. The 'scope is measuring voltage between the probe and the ground clip, which you had across the exact quantity that you wanted to measure.
  2. Probably because either your 'scope or your circuit is floating/ungrounded. Both need to be grounded for that to be a problem. Good power supplies from AC mains will always isolate the circuit being powered and will thus require re-grounding as desired.
  3. Probably because the sensitivity is identical between instruments, as it should be.
  4. Probably because the meter, the 'scope, or both have a DC offset that is incorrect. 'Scopes are known for capturing fast signals, not so much for DC accuracy, though they're usually pretty good. If you have a low impedance meter, that could also throw off the reading, but it would probably affect the dynamics too if that were the case.
The reason that you're "supposed to" use two probes and a math function is to handle the case where both the 'scope and circuit are grounded and you want to measure something that is not referenced to ground.
For me, I keep my 'scope ungrounded and be careful of what I'm getting into. All of my controls are plastic (but there are often unused BNC connectors), and I only ever use one ground clip unless I have a really good reason. That ground clip then becomes my reference for everything. However, that only works for relatively slow stuff because the loop area between probes can become an RF antenna.
