I want to generate Interrupt(on PIC18f4550 using TIMER0) every 1 sec but by using the following code interrupt is generated after every 6 secs.
#include<pic18f4550.h>
#pragma config PLLDIV = 5 , CPUDIV = OSC1_PLL2 , USBDIV = 2
#pragma config FOSC = INTOSCIO_EC
#pragma config FCMEN = OFF
#pragma config BORV = 3
#pragma config WDT = OFF
#pragma config CPB = OFF
#pragma config CPD = OFF
void intinter(void);
void inittimer(void);
void interrupt low_priority timerinterrupt(void);
void main()
TRISB =0x00; // Port B as output for LCD
PORTB =0xff;
intinter(); // Initialise Interrupt
inittimer(); // Initialise Timer
TMR0ON =1; // Timer 0 on
while(1);
void intinter(void)
RCONbits.IPEN =1; //Low priority enable
INTCON = 0b11100000; //timer 0 interrupt enable
INTCON2bits.TMR0IP = 0; //set timer 0 int. low priority
T0CON = 0b00000111; //prescaler of 256, 16 bit, internal clock
TMR0H = 0xED; // Set TMRH and L Value
TMR0L = 0xB0;
void interrupt low_priority timerinterrupt (void)
if(TMR0IF == 1)
TMR0ON =0;//Timer 0 off
TMR0IF = 0; //Timer 0 IF disable
TMR0H = 0xED;
TMR0L = 0xB0;
PORTB = ~ PORTB; //complement port B
TMR0ON = 1; //Timer 0 on
I am setting the internal clock at 20MHz and I think the problem is in the values of TMR0L and TMR0H. Can someone please guide me, how to set correct values for these and get 1sec interrupt if it is possible. Or there is another way to do it.
Thank you.
did that. Am I wrong? \$\endgroup\$ – Mohit Mar 10 '15 at 19:45
