I'm thinking of making the following circuitry:
PC <-> Ft2232h <-> MCU
(I'm using the MCU just for an initial test to see if I can get the ft2232 working. An FPGA will be used later)
Have I understood the following read/write procedures correctly?
In order to read from the MCU to the PC:
1. Set the pins (on my MCU) connected to D7-D0 (channel A or B), to the required logic level representing the data to be read.
2. Set CS# = 0, A0 = 0.
3. Toggle RD# from high to low and then high again.
In order to write to the MCU from the PC:
1. Set CS# = 0, A0 = 0.
2. Toggle WR# from high to low and then high again.
3. Read from the pins (on my MCU) connected to D7-D0 (channel A or B)
You have the functions of RD# and WR# backwards. As shown on page 40 of the datasheet, RD# is used to transfer data from the FT2232H to the MCU (which is "writing" from the host PC's point of view), and WR# is used to transfer data from the MCU to the FT2232H, from where it can be read by the host PC.
two issue: 1. A0 need high-low transform, so that data will load to buffer and then from buffer output to IO pin. See datasheet Page 40, table 4.7.
  1. read=> data from FT2232H output; write=> data input to FT2232;
