In this schematic, there is a reset circuit with two pushbuttons:
The button marked "warm reset" sends an active low signal to one microcontroller, while the button marked "cold reset" sends a signal to all the microcontrollers on the board. The signal to all of them is normally pulled up by the resistors. Can you help me design a power-up reset circuit for this board? I looked online but most schematics are for active-high signals. I was thinking the correct way to do this is to connect a 10uf capacitor instead of the ground symbol at the bottom of the reset circuit, with the negative side connected to ground. Is this right and if not, what is correct?
  • \$\begingroup\$ Don't forget that the reset inputs typically have minimum acceptable voltage slew rates. Your RC circuit must slew fast enough, or else the microcontrollers' state will be indeterminate. Worse yet, it might appear to work, but some peripherals might misbehave. \$\endgroup\$ Mar 12, 2015 at 21:49
If you want a reliable power-up reset, a simple RC is not the way to do it.
The capacitor you suggest (plus a diode across R1 to discharge the capacitor when power is removed) will sort-of work most of the time, and some crappy products actually use something like that.
Instead it would be better to use a supervisory circuit such as an ADM803 (open drain output), which combines a voltage reference and comparator that work down to a low supply voltage with a RC timer that produces a reasonable length reset pulse when the supply voltage reaches or recovers to an acceptable level. I also don't think much of using the diode rather than a gate- it does not guarantee a proper TTL low level even with a switch, and that issue may cause problems (perhaps immediately, perhaps at low temperatures) when a reset circuit is used since the reset circuit won't pull the output quite as low as a mechanical switch will. Using a push-pull supervisory circuit (ADM809, IIRC) and a quad NAND gate (connected as two AND gates) with the two mechanical switches would make it all kosher (or halal).
    \$\begingroup\$ I'm only building one, I don't really care about reliability, and electronic components are hard to get here while I already have a capacitor, resistor and diodes. As I didn't mention that in the question though, I'm going to accept this. \$\endgroup\$
    – user60684
    Mar 12, 2015 at 18:45
  • \$\begingroup\$ Okay, if you're going to do this you might want to put a few ohms in series with the capacitor (not too much for the same reason as mentioned above with the diode) to keep from welding the switch contacts. A bit higher capacitance might be necessary depending on your power supply ramp up (I don't think 100uF or even 220uF is too high with 4K7 || 4K7 pullup). \$\endgroup\$ Mar 12, 2015 at 19:01
