Using a 1x8 deMUX with an AND gate, create F(x,y,z) where F has minterms at 1,3 and 5
This is the solution I came up with:
I'm pretty sure this solution works, but it doesn't quite fit the specifications. Can anyone help me do this with only one AND gate?
EDIT
Here is my function table
  • \$\begingroup\$ please show your output truth table :) \$\endgroup\$ – Alexander Sabiona Mar 13 '15 at 0:32
  • \$\begingroup\$ @tcrosley I'm using a 1x8 deMUX. The selects should choose an output to have the value of the data input. \$\endgroup\$ – Dunka Mar 13 '15 at 0:39
  • \$\begingroup\$ @AlexanderSabiona It is uploaded now \$\endgroup\$ – Dunka Mar 13 '15 at 0:46
  • \$\begingroup\$ @tcrosley they take in xyz as inputs, the xyz also goes to the data inputs \$\endgroup\$ – Dunka Mar 13 '15 at 2:56
Maybe everyone's over thinking this (or I'm missing something).
I don't think you need the logic going into D, just tie D to 1. Then, route M1, M3, and M5 into the OR gate whose output is F. The output will be 1 for just the correct entries of x,y and z, and 0 otherwise (i.e. 111 will have a 0 output since M7 is not fed into the OR gate).
So that's how to do it with one OR gate. Not sure about AND ...
Heya :) I doubt you can do this with a single AND gate only. Are you allowed to use inverted AND (NAND) gates? if so, then try converting that OR into a NAND.
