Hi I am building a motor controller and I decided to use PSMC instead of CCP to create my PWM, my decision was based on the fact that I dont have enough CCP ports on my pic 16f1788 for the project. I am using the PSMCdesigner module provided by Microchip. I went through it and generated my code but unfortunately the code doesn't work. I know how to program CCP but never worked with PSMC before I would like to get some help here is the code I generated through the program.
#include <xc.h>
// Config word
// CONFIG1
#pragma config FOSC = INTOSC // Oscillator Selection (INTOSC oscillator: I/O function on CLKIN pin)
#pragma config WDTE = ON // Watchdog Timer Enable (WDT enabled)
#pragma config PWRTE = OFF // Power-up Timer Enable (PWRT disabled)
#pragma config MCLRE = ON // MCLR Pin Function Select (MCLR/VPP pin function is MCLR)
#pragma config CP = OFF // Flash Program Memory Code Protection (Program memory code protection is disabled)
#pragma config CPD = OFF // Data Memory Code Protection (Data memory code protection is disabled)
#pragma config BOREN = ON // Brown-out Reset Enable (Brown-out Reset enabled)
#pragma config CLKOUTEN = OFF // Clock Out Enable (CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin)
#pragma config IESO = ON // Internal/External Switchover (Internal/External Switchover mode is enabled)
#pragma config FCMEN = ON // Fail-Safe Clock Monitor Enable (Fail-Safe Clock Monitor is enabled)
// CONFIG2
#pragma config WRT = OFF // Flash Memory Self-Write Protection (Write protection off)
#pragma config VCAPEN = OFF // Voltage Regulator Capacitor Enable bit (Vcap functionality is disabled on RA6.)
#pragma config PLLEN = ON // PLL Enable (4x PLL enabled)
#pragma config STVREN = ON // Stack Overflow/Underflow Reset Enable (Stack Overflow or Underflow will cause a Reset)
#pragma config BORV = LO // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (Vbor), low trip point selected.)
#pragma config LPBOR = OFF // Low Power Brown-Out Reset Enable Bit (Low power brown-out is disabled)
#pragma config LVP = ON // Low-Voltage Programming Enable (Low-voltage programming enabled)
void main(void)
PSMC1CON = 0x00;
PSMC1MDL = 0x00;
PSMC1SYNC = 0x00;
PSMC1CLK = 0x30;
PSMC1POL = 0x00;
PSMC1BLNK = 0x00;
PSMC1REBS = 0x00;
PSMC1FEBS = 0x00;
PSMC1PHS = 0x00;
PSMC1DCS = 0x00;
PSMC1PRS = 0x00;
PSMC1ASDC = 0x00;
PSMC1ASDL = 0x00;
PSMC1ASDS = 0x00;
PSMC1PHH = 0x00;
PSMC1PHL = 0x14;
PSMC1DCH = 0x00;
PSMC1DCL = 0x00;
PSMC1PRH = 0x00;
PSMC1PRL = 0xC7;
PSMC1DBR = 0x00;
PSMC1DBF = 0x00;
PSMC1FFA = 0x00;
PSMC1BLKR = 0x04;
PSMC1BLKF = 0x02;
PSMC1STR0 = 0x3F;
PSMC1STR1 = 0x80;
PSMC1INT = 0x00;
PSMC1OEN = 0x05;
PSMC1CON = 0x80;
PIE4 &= 0xEE;
PIE4 |= 0x00;
