Last time i used the Slide Switch for my application, everything worked well. The system has 2S (7.4v Lipo) Battery - Fuse - On/Off Switch - Switching Regulator - load ( Beaglebone + Wifi Module).
Now when i rechecked the website, i realized the switch is rated 12v 100mA. This is the scary part, although nothing got burnt or fried the last time, do i need to change the switch? can i use the same switch?
Is it better to use a rocker switch with a higher current specification and have it connected via a wire?
