I am using an ATtiny841 microcontroller as an I2C slave, but I have difficulty finding information on it. So for, all I have are application notes and reference code for TWI and USI module.
It seems like ATtiny841 has a unique TWI slave interface, which is slightly different. Although I could write out the code manually it would really help if there is a standard sample code that I can refer to.
Any suggestions?
Thanks in advance.
    \$\begingroup\$ Does AVR311 not contain what you need? \$\endgroup\$ Mar 17, 2015 at 1:23
  • \$\begingroup\$ AVR312: Using the USI module as a I2C slave atmel.com/Images/doc2560.pdf \$\endgroup\$
    – vicatcu
    Mar 17, 2015 at 2:06
  • \$\begingroup\$ @Ignacio: Yes, AVR311 is the one that I'm currently referring to. It is based on the more general TWI module found in ATmega controllers. \$\endgroup\$
    – bot3663369
    Mar 17, 2015 at 4:13
  • \$\begingroup\$ @vicatcu: I have used USI on other ATtiny controllers, but 841 does not have USI. \$\endgroup\$
    – bot3663369
    Mar 17, 2015 at 4:16
You should be able to use the TWI example code as-is, since TWI is I2C: What is difference between I2C and TWI?
