I´ve been searching for libraries or documentations for helping me reading from and writing to the acell + gyro breakout MPU-6050 from InvenSense. I managed to read it with the arduino's libraries made by Jeff Rowberg (Link), but now I want to use the TI MSP430g2553 (with the CCS or IAR). I intend to make a good library and some examples in order to share it, since I can`t find it as easily as I found for Arduino and PIC.
The code I have so far seems to work, but I cant be certain. The most basic test is to read the WHO_AM_I register, which returns the slave address (0x68). The code I used is based on this topic, which is based on a TI documentation.
My code is very simple:
Includes:
#include <msp430g2553.h>
#include "MPU6050.h"
Prototypes:
void init_I2C(void);
int i2c_notready(void);
char Receive(char);
void Transmit(char, char);
Main:
int main(void) {
volatile char who_am_i;
char test;
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
BCSCTL1 = CALBC1_1MHZ; // Set DCO to 1Mhz
DCOCTL = CALDCO_1MHZ;
P1SEL |= BIT6 + BIT7; // Assign I2C pins to USCI_B0
P1SEL2 |= BIT6 + BIT7; // Assign I2C pins to USCI_B0
init_I2C(); // initialize i2c
__delay_cycles(10000);
while ( i2c_notready() ); // wait for bus to be free
who_am_i = Receive(MPU6050_RA_WHO_AM_I);
while(1) {}
Functions:
void init_I2C(void) {
UCB0CTL1 |= UCSWRST; // Enable SW reset
UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC; // I2C Master, synchronous mode
UCB0CTL1 = UCSSEL_2 + UCSWRST; // Use SMCLK, keep SW reset
UCB0BR0 = 10; // fSCL = 1Mhz/10 = ~100kHz
UCB0BR1 = 0;
UCB0I2CSA = MPU6050_DEFAULT_ADDRESS;
UCB0CTL1 &= ~UCSWRST; // **Initialize USCI state machine**
IE2 |= UCB0RXIE + UCB0TXIE; // Enable RX and TX interrupt
int i2c_notready(){
if(UCB0STAT & UCBBUSY) return 1;
else return 0;
char Receive(char registerAddr){
char receivedByte;
while (UCB0CTL1 & UCTXSTP); // Ensure stop condition got sent
UCB0CTL1 |= UCTR + UCTXSTT; // I2C start condition with UCTR flag for transmit
while((IFG2 & UCB0TXIFG) == 0); //UCB0TXIFG is set immidiately
UCB0TXBUF = registerAddr; //write registerAddr in TX buffer
while((IFG2 & UCB0TXIFG) == 0); // wait until TX buffer is empty and transmitted
UCB0CTL1 &= ~UCTR ; // Clear I2C TX flag for receive
UCB0CTL1 |= UCTXSTT + UCTXNACK; // I2C start condition with NACK for single byte reading
while (UCB0CTL1 & UCTXSTT); // Start condition sent? RXBuffer full?
receivedByte = UCB0RXBUF;
UCB0CTL1 |= UCTXSTP; // I2C stop condition
return receivedByte;
void Transmit(char registerAddr, char data){
UCB0TXBUF = data; //Write data in register
IFG2 &= ~UCB0TXIFG; // Clear TX interrupt flag
The problem is: I can only get the data if I try to read twice. That is, I can only get the register value if I write the line
twice. (And I do get the expected value).
It may be silly, but I think this is happening becouse I misunderstood something that could lead to total misfunction of the complete code. Therefore I would like to solve or understand this problem before geting any further on my Code. Thank you very much.
