I am using this circuit to control a motor.
Initially I was using 12V PWM generated from a 555 astable circuit. I am now trying to make the circuit controllable via an 8051 Microcontroller
The problem seems to arise when I apply a digital PWM. The motor does opperate, but at a low torque/speed. The digital PWM is of course only 5V. Upon playing around with my circuit, I noticed that if I disconnect the 12V that's powering my H-Bridge, the motor will still run just fine. Thus, I've discovered that the H-Bridge is being completely powered by my PWM voltage.
Is there a way I can amp up the voltage of my PWM? I've tried Op Amps, but that limits the current being delivered and doesn't allow my motor to start. Or is there a way to make my H-Bridge use the voltage I power it with and only control speed/direction based on my PWM signals?
While the FET's are as a H-Bridge, the drive isn't and yes the motor is being directly driven by the PWM
Let me redraw it to be a bit clearer
Basically the TOP Ptypes are always held OFF due to their GATE being tied to 12V
You have PWM going into the gate of the LOWER-RIGHT FET (which will turn it ON). This will pull the RIGHT terminal of the Motor to 0V.
The problem then is the PWM is connected to the midpoint of the LEFT-LEG and thus current from the PWM will flow through the MOTOR down the LOWER-RIGHT FET
Thus your PWM is powering the motor.
How to fix? remove the connections from the lower GATES to the phase connections. Include another FET to provide as a 5V --> 12V logic conversion. This will allow you to then drive the UPPER FET's.
Connect the FET gates to this FET-buffered PWM
| improve this answer | |
  • \$\begingroup\$ I've made this comment before and I suppose that I'll have to do it again. The above circuit either won't work at all or won't work very well. Why not breadboard it and see what happens? Monitor the current in the bottom FET source leads. FWIW - I bread-boarded it with IRF540 & IRF9540 FETs. These are FETs requiring a nominal 10V gate drive - not logic-level FETs. They were NOT happy! \$\endgroup\$ – Dwayne Reid Mar 19 '15 at 23:54
  • \$\begingroup\$ To be fair, what was posted here was FET agnostic... One would hope the two FET's that are driven from the PWM src are logic compatible... There was a lot wrong in the 1st circuit. Correcting the fundamental misunderstanding is required before moving on to correct gatedrive which I have said many a time \$\endgroup\$ – JonRB Mar 20 '15 at 0:02
