I'm thinking of doing a small-scale Solar off-grid setup 1-2 80 Watt panels with a 12v 40Ah Deep Cycle battery. I have questions for those parts in another thread, but for now, my question is about understanding what to look for in a battery controller. Kindly see the example on this link.
I will copy paste the specs written:
- Technical date SMR05
- Nominal voltage 12V/24V, automatic recognition
- Max solar current or load current 5A
- Over charge voltage14.6V/29.2V
- Over charge release voltage 14.0V/28.0V
- Over voltage protection 15.6V/31.2V
- Load disconnect voltage 10.5/21V
- Load reconnect voltage 11.5V/23V
- Lighting hours 0-18hours
- Night/day detect 3.0-7.5V/6.0-15.0V
- Battery type Liquid,Gel
- Max solar voltage 55V
- Max battery voltage 40V
Kindly correct me on my understanding of this specs:
- Model
- The battery to be putted can either be a 12 volt or 24 volt?
- the solar panel's current can not exceed 5A (Solar panel in Parallel should not total over 5A)?
- 14.6V for 12V is the indicator that the battery is 100% charge?
- 14.0V is the time where the controller will pass the excess energy to the Load?
- Protection for the battery.
- If the controller detect the drop of v taken from the panel is at 10.5, the load part will be disabled? Or if the voltage drops at 10.5 the controller will not charge the battery?
- Battery will charge at 11.5V? or the Load (excess energy) will be re-activated?
