My girlfriend bought an LED faucet that is actuated when you turn the water on and is powered by a battery pack of 4 AA batteries (2 wire out).
led faucet example
However, when the water is turned off, the slope of the faucet is rarely sufficient to overcome the surface tension and the faucet remains on. How can I build a timeout circuit such that the faucet turns off after being lit for 5-10 minutes and stays off unless water is fully cleared from the faucet and then the faucet is turned on again?
A friend of mine recommended a 555 chip, but after looking into it it seem the faucet would just turn off after 5 min, then turn back on 5 min later and keep cycling indefinitely.
I tried searching this site and came across this question that seem similar, but can't figure out how to deal with the fact that the activation of the circuit would work more like a toggle switch than a push button.
Thanks!
Yes, a 555 would do the job. The 555 can work in a number of ways - the one you are looking for is called "Monostable". This triggers once on the press of a button and turns itself off after a certain amount of time. Nothing happens until you press the button again.
Replacing the button with a capacitor effectively gives you a single press of the button at power-on time and nothing after that.
Something along the lines of (though I haven't tested it of course):
  • R1 and C2 define how long it stays turned on for (around 363 seconds that should be with those values).
  • C1 and R2 cause a delay on the trigger rising at power-on (you may want to increase C1 slightly for more initial delay).
  • The 555 when activated turns on Q2 which in turn turns on Q1 which allows the power to flow to the LEDs.
By the way, this circuit was inspired by: http://555-timer-circuits.uk/operation/one-shot2.html
  • \$\begingroup\$ Thanks, I think the C1 / R2 circuit explains how to make a trigger that turns off. However I have some concerns: the switch(water) and the LEDs are in-line and there's really no way for me to separate them from one another, but if I understand the diagram, the LEDs are suppose to be between Q1 and Q2, while the switch is between Q1 and ground correct? \$\endgroup\$
    – virtualxtc
    Mar 23 '15 at 3:31
  • \$\begingroup\$ Forgive me - I omitted that kind of detail from the circuit. I have updated the circuit to show where the existing switch unit would connect (between the battery and the 555 circuit) and where the LEDs connect (plus whatever drive / current control circuit they have). \$\endgroup\$
    – Majenko
    Mar 23 '15 at 11:14
  • \$\begingroup\$ No worries, I'm sure it would have been obvious to anyone who has taken an EE course; the wikipedia page on BJTs is very dense and full of argots. \$\endgroup\$
    – virtualxtc
    Mar 23 '15 at 15:51
