While using 8085 especially at a different baud-rate ,
DTE being the micro-controller, DCE being any modem/or a Display device coupled with
RS232 db9 or db25 port.
I can understand SBUF can Store upto 8 bit of data when its full, it gives A TI high
ie it hires a transmitter interrupt,
But Iam confused whether this SBUF (mentioned in program) bleongs to the DTE or DCE,
Suppose there is a program,To transmit at baudrate 4800,
ORG 00H;
00 MOV SCON #50H;
01H MOV TMOD #20H;
02H MOV TH1,-6;
03H MOV A,#'Y';
04H CALL PRINT;
05H MOV A,#'E';
06H CALL PRINT;
07H MOV A,#'S';
08H CALL PRINT;
09H CLR TI;
0AH SJMP 03H;
PRINT: MOV SBUF,A;
P1: JNB TI,P1;
RET;
Also during transmission of 'Y' to the receiver of the DCE, REN flag must be enabled, there is a need for both the sides to understand the tranmission of data(first 8bit has taken place, which this program seriouly misses) and we use TI for that , but can we address both ends SBUF in a single program?
