I am working on an ATtiny85 USB development board, and I need to flash the Micronucleus bootloader on it. I have heard that this bootloader allows the ATtiny85 to be programmed via USB from the computer, without the need of an external programmer.
So I decided to try to burn it, using the Arduino Uno as ISP. I downloaded the bootloader, AVRDUDE, opened the command prompt (I'm using Windows 8.1), navigated to the .hex file folder and wrote this:
avrdude -c arduino -b 19200 -P COM6 -p t85 -U flash:w:micronucleus-1.06.hex -U lfuse:w:0xe1:m -U hfuse:w:0xdd:m -U efuse:w:0xfe:m
Does that sounds right? That's what the prompt outputs:
C:\Users\Mohamed\Desktop\micronucleus-master\firmware\releases>avrdude -c arduin
avrdude: please define PAGEL and BS2 signals in the configuration file for part
ATtiny85
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e930b
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
ATtiny85
avrdude: reading input file "micronucleus-1.06.hex"
avrdude: input file micronucleus-1.06.hex auto detected as Intel Hex
avrdude: writing flash (8162 bytes):
Writing | ################################################## | 100% 3.91s
avrdude: 8162 bytes of flash written
avrdude: verifying flash memory against micronucleus-1.06.hex:
avrdude: load data flash data from input file micronucleus-1.06.hex:
avrdude: input file micronucleus-1.06.hex contains 8162 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 9.37s
avrdude: verifying ...
avrdude: 8162 bytes of flash verified
avrdude: reading input file "0xe1"
avrdude: writing lfuse (1 bytes):
Writing | ################################################## | 100% 0.02s
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xe1:
avrdude: load data lfuse data from input file 0xe1:
avrdude: input file 0xe1 contains 1 bytes
avrdude: reading on-chip lfuse data:
Reading | ################################################## | 100% 0.03s
avrdude: 1 bytes of lfuse verified
avrdude: reading input file "0xdd"
avrdude: writing hfuse (1 bytes):
Writing | ################################################## | 100% 0.03s
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xdd:
avrdude: load data hfuse data from input file 0xdd:
avrdude: input file 0xdd contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xfe"
avrdude: writing efuse (1 bytes):
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0xfe:
avrdude: load data efuse data from input file 0xfe:
avrdude: input file 0xfe contains 1 bytes
avrdude: reading on-chip efuse data:
Reading | ################################################## | 100% 0.01s
avrdude: 1 bytes of efuse verified
avrdude: safemode: Fuses OK
avrdude done. Thank you.
Is it flashed now? Because when I plug it in the USB port I get this error message: "USB device not recognized". Do I have to install some driver, or flash anything else on the ATTiny85?
