I'm using a p-channel mosfet to switch a 3.5V load, using a gate voltage that's ~5V. The gate goes from 5V to 0V, but the mosfet doesn't start conducting. Did I just fry the mosfet by having the gate be above the source, or is something else happening?
\$\begingroup\$ Could you post the datasheet for the MOSFET, please? \$\endgroup\$– Nick AlexeevMar 26, 2015 at 3:10
\$\begingroup\$ @NickAlexeev Done. And - I'm using it because I have it in my "lab stock." This is all breadboarded right now. Easy enough to change, if need be. \$\endgroup\$– kolosyMar 26, 2015 at 3:24
\$\begingroup\$ This MOSFET is clearly not designed for switching low voltages with a TTL signal on the gate. \$\endgroup\$– Matt YoungMar 26, 2015 at 3:33
\$\begingroup\$ @MattYoung it's certainly not an ideal part, but it has a Vgs of min/max -2V/-4V, which I'm providing. \$\endgroup\$– kolosyMar 26, 2015 at 3:44
1\$\begingroup\$ Look at the conditions for those thresholds, and Michael Karas' answer. \$\endgroup\$– Matt YoungMar 26, 2015 at 3:58
1 Answer
It is OK for this MOSFET to have the gate higher voltage than the source. The data sheet says that the part can handle +/- 25V on the gate.
Note that the 2->4V spec is the range of gate->source threshold voltage for just barely turning on part to 250uA of drain current.
The gate voltage is referenced with respect to the SOURCE terminal of the part. If you are attaching the source to a 3.5V supply and with the load then connected from the DRAIN to ground then you are going to need to have a gate drive that is at least 4V below the 3.5V level to get the FET to barely turn on. If you want to achieve the data sheet specified low RDSon of 0.055 ohms the gate will need to be -10V with respect to the source or a whopping 6.5V below the ground level.
Like somebody said in the comments. This FET and your driving configuration are not suitable for switching a load on and off from a 3.5V supply. Come up with a negative rail to swing the gate to and then it might work.
