I have an ATtiny AVR imicrocontroller connected to HC-05 bluetooth module via USART(TX and RX) of the microcontroller. The microcontroller is sending constant data (for right now) to the bluetooth module, which I am viewing as serial data using python.
The problem is that i am seeing all data as '\xff' ,or '\xfd' or ... i.e. the MSB is always f. I don't see a reason why this should happen. Somebody please help!
This is my code :
void USART_initialize(int baud_value) {
//int baud_rate = (unsigned int)(((16000000)/(16*baud_value))-1);
UCSRC = ~(1<<UMSEL);                        // MODE OF COMMUNICATION
UBRRH = (unsigned char)(25 >> 8);   // SETTING BAUD
UBRRL = (unsigned char)(25);        // RATE
UCSRC |= (3<<UCSZ0);                         // 8-BIT DATA
UCSRC |= (1<<UPM1);                         // EVEN PARITY
UCSRC &= ~(1<<USBS);                        // 1 STOP BIT
UCSRA &= ~(1<<U2X);                        // NORMAL ASYNCHRONOUS MODE OF COMMUNICATION
UCSRB = (1<<RXEN)|(1<<TXEN);               // ENABLE RECEIVER & TRANSMITTER
} int main (void) {
DDRB = 0xFF;
DDRA = 0x00;
DDRD = 0xFF;
int8_t data;
USART_initialize(9600);
while(1) {
    while(!(UCSRA & (1<< UDRE)));
    UDR = ('0b00000001');
    data = '\n';
return(0);
  • \$\begingroup\$ Are you sure that the value of 25 you're loading into your baud rate divisor register is correct for the rate you're aiming for? \$\endgroup\$
    – brhans
    Commented Mar 26, 2015 at 15:53
Possibility 1
Your avr-to-bluetooth connection does not have flow control and receiving side does not verify the stop bit.
There should be a compounding problem of wrong baud rate or just broken transmission.
In this case you'll see bursts of broken data when you expect data and nothing otherwise.
Possibility 2
You are missing a pull-up or pull-down (depending on ttl/rs232 signal), thus every little bit of noise triggers reception of a character.
If this is the case, you will receive a lot more data than you expect, in fact you'll probably receive continuous stream of data. Check number of characters received per second against baud rate / 10 (start, 8 data, stop)
  • \$\begingroup\$ i modified the code to send only one byte per second but then too i get a lot more data. What could be the problem ? Do i have to use a pullup/ pulldown resistor at the TX/RX pins ? \$\endgroup\$
    – ironstein
    Commented Mar 19, 2015 at 9:16
  • \$\begingroup\$ You would need a pull-up at the logic input (i.e. RS-232 idles at Mark which is logic high.) \$\endgroup\$
    – sawdust
    Commented Mar 19, 2015 at 10:05
  • \$\begingroup\$ @sawdust i connected a pullup resistor of 1.2K to the RX of the bluetooth module but to no use. Still reading senseless data. Please help ! \$\endgroup\$
    – ironstein
    Commented Mar 19, 2015 at 10:30
  • \$\begingroup\$ do i have to do any initialization before using the bluetooth module (HC-05) or is it simply plug and play ? \$\endgroup\$
    – ironstein
    Commented Mar 19, 2015 at 11:33
  • \$\begingroup\$ I used a similar HC-something module and though you don't need to initialise it explicitly every time, these is a protocol to configure it the first time, in particular the bauds rate. Check the datasheet for that. \$\endgroup\$ Commented Aug 23, 2015 at 7:27
