Can I use an AND gate with a clock input? For example, in the picture below, I have a positive-edge D flip-flop. I'm using an AND gate with the Select_chip input and the Clock input but I'm not sure if this works. When the clock is assigned to a push button, the button will start at high, and then when I press it it will go low to high causing a positive-edge. But with an AND gate, it doesn't seem to work in my mind...
EDIT: I thought about it a little more, let's say Select_chip will be on HIGH always, then if the push button for the Clock starts at high, and if I press the button, the AND gate output will be low since the "Write_enable/Clock" will go low, which inputs into the flip flop changing high to low, and then when the button comes back up, Write_enable is high, making AND gate's output high, therefore changing the flipflop's Clk from low back to high causing a positive edge trigger.
Is my logic correct? I'm not sure.
