I have this simple dc jfet circuit (homework):
Circuit
First of all I had to find the values of the drain and source resistors given the data above, this was pretty simple and I got: $$R_D=4k\Omega $$ $$R_S=11k\Omega $$
Next, \$I_{DSS}\$ get's doubled to \$8mA\$, now I'm asked to find \$I_D\$.
Using: $$I_D = I_{DSS}\left [ 1-\frac{V_{GS}}{V_P} \right ]^{2} $$
I've found out that: $$I_{D1} =1.16mA$$ $$I_{D2} =1.0258mA$$
During the calculations I've assumed the transistor is saturated thus: $$V_{DG} > V_P $$ It seems like both \$I_D\$'s fulfill the above requirement.
How can I tell which one is correct ?
  • \$\begingroup\$ Have u already checked if both currents fulfill your saturated supposition? \$\endgroup\$ Mar 27, 2015 at 14:04
  • \$\begingroup\$ I have, I get \$V_{DG} = 5.36v\$ and \$V_{DG} = 5.9v\$ respectivly, they are both larger than \$V_P = -2\$ \$\endgroup\$
    – Mike
    Mar 27, 2015 at 14:19
  • \$\begingroup\$ Well if you see mathematically , Id is directly proportional to Idss. For Idss = 4 mA , Id = 1 mA . So for Idss = 8 mA, Id = ?? (I think I'm right, just a bit confused why no one else has pointed this out. Feel free to correct me) \$\endgroup\$ Mar 27, 2015 at 15:23
  • \$\begingroup\$ but \$ V_{GS} \$ is also a function of \$I_D\$ \$\endgroup\$
    – Mike
    Mar 27, 2015 at 16:18
    \$\begingroup\$ @Mike But \$V_S = 3V\$ will also satisfy the current equation. See my answer. \$\endgroup\$
    – nidhin
    Mar 28, 2015 at 9:03
The image (taken from wikipedia) below shows the JFET chara. It can be seen that the drain current reduces to zero as \$V_{GS}\$ approaches pinch off (\$V_{P}\$). And the channel is off for \$|V_{GS}|>|V_{P}|\$ and no current flow happens.
So the transistor is in saturation and the Shockley's equation
is valid only if \$|V_{GS}| < |V_P|\$ and \$V_{DG} > V_P\$.
Now calculating \$V_{GS}\$ in your case,
case1: \$I_{D1} =1.16mA\$ $$V_{GS} = -2.76V$$ But \$V_{P}=-2V\$ so \$|V_{GS}| > |V_P|\$ and hence transistor is in cut-off.
case2: \$I_{D2} =1.0258mA\$ $$V_{GS} = -1.2838V$$ Here, \$|V_{GS}| < |V_P|\$ and hence transistor is in saturation.
So \$I_{D} =1.0258mA\$ is the correct answer.
PS: You should have faced this problem while calculating the value of \$R_S\$ also.
$$1mA = 4mA\left( 1 + \dfrac{10-1mA\times R_S}{2}\right)^2$$
\$R_S = 11k\Omega\$ and \$R_S = 13k\Omega\$ will satisfy this equation. The value \$R_S = 13k\Omega\$ can not be used because of the same reason discussed above.
