6
Can anybody tell me the name of the connector shown in these photos? (I mean the biggest one, which is centered in the photos)
First connector photo
Second connector photo
    \$\begingroup\$ Interestingly non-typical board that uses component value designators instead of reference designators. \$\endgroup\$ Mar 28, 2015 at 12:57
    \$\begingroup\$ Since some have asked, the pitch is actually pretty close to 0.156'', as many have guessed. \$\endgroup\$ Mar 28, 2015 at 13:06
  • \$\begingroup\$ -1 and vote to close. This is clearly a shopping question where the OP hasn't even bothered to try to identify the connector. \$\endgroup\$
    – EM Fields
    Mar 28, 2015 at 14:24
    \$\begingroup\$ @EMFields I tried, I searched on the web, but there are a lot of connectors out there and I could not find it. Do you have good resources to find connectors quickly? How do you know that I did not try? It is not a shopping question: I am not asking "Where do I buy it?", but "What is it?". \$\endgroup\$ Mar 28, 2015 at 15:42
    \$\begingroup\$ "I want to buy..." targets it as a shopping question, and its manufacturer can be used to connect the dots to a distributor, therefore killing two birds with one stone and solving a logistics, not a design problem. A good starting point to find connectors quickly would be DigiKey's menu system, where starting at the top and punching in:Product Index > Connectors, Interconnects > Rectangular Connectors - Headers, Male Pins will lead you to a page where exactly what you want exists and, since you know the number of pins, the pins' cross-sectional dimensions and pitch, you can easily find it. \$\endgroup\$
    – EM Fields
    Mar 28, 2015 at 19:28
8
That connector looks to me to be a power type connector with connector pins on 0.156" centers. You can find styles of these from mainstream connector manufacturers such as TE, Molex and others.
This connector for example is Molex part number 09-65-2068 which you can find at www.mouser.com.
In the industry these are often called KK series connectors.
It is a 0.156"-pitch connector, very common for power connections. One popular line is made by Molex.
  • \$\begingroup\$ Sorry to be pendantic, but this is 0.156" pitch as you've identified, but it's not Mini-Fit, it's KK, here's the link molex.com/molex/products/… , the key difference is that Mini fit has pins which are 100% individually shrouded. \$\endgroup\$ Apr 1, 2015 at 7:42
-3
Looks like a 0.1" pitch connector. They're very common, but there isn't a generic name for them. Just use any popular distributor's website and filter on the pitch dimension.
  • \$\begingroup\$ It might be 2.5mm pitch - are your eyes that good? \$\endgroup\$
    Mar 28, 2015 at 11:51
  • \$\begingroup\$ Coincidentally, good to +/- 0.04mm ;). It would probably behoove the OP to take out his calipers though. \$\endgroup\$
    – Dan Laks
    Mar 28, 2015 at 11:57
  • 4
    \$\begingroup\$ No, it's a 0.156"-pitch connector, very common for power connections. Compare the spacing in the first picture to the 0.05" lead spacing of the SOIC nearby. Also, you can see 0.100"-pitch connectors in the second picture, on the right side. \$\endgroup\$
    – Dave Tweed
    Mar 28, 2015 at 12:46
