The 5 nanometer process is expected (According to the Intel Roadmap) to be in 2020. In this Wikipedia article, in the first paragraph, they say that:
5 nm was once assumed by some experts to be the end of Moore's law. Engineers have since exceeded this theoretical limit by creating 1 nanometer transistors.
Does that mean the number of transistors in an IC will double in less than what Moore specified in his law ? Or something else ?
First of all, you have to define what Moore's law means. Initially, Moore defined it as the number of components on a single IC.
This is easy to achieve by increasing the size of the die (the piece of silicon). But as there are also limits to this size (mainly cost and yield, but also signal propagation delay for fast ICs), you try to shrink the ICs.
So, today Moore's law is often defined as number of components per area. Sometimes it is also used for performance per CPU or similar, but this is not the intention of the law.
Now about your question:
If there is a technology to produce an IC, it first may be not be perfect. The contours of the structures are not very precise / straight, but the production has a good yield. During production, experience and small improvements lead to a higher precision, which allows you to shrink your structure.
This will not go on forever, because once you will encounter insolvable problems with your current technology. To overcome this problems, you need to apply major changes to the existing techology, or even use a new technology.
However, the question is if there is a final, hard limit. This 5nm is a guess for such a limit. But this limit bases on limits of current technology and expected / extrapolated limits for future technologies or just physical limits. Silicon atoms have a diameter of ~0.2nm, so a 5nm structure is about 20 atoms wide. So, this limit sounds reasonable. But if you change to other materials or use other physical effects, you may be able to overcome this limit.
Finally, there is a big difference between being able to produce a 1nm structure in the lab and producing an IC with billions of 1nm structures. As said above, the yield may be 1% at the moment, which is fine for demonstration of the process, but bad for production. Also, I don't know how they created this transistors, but may be, this technology is not feasible for more complex structures and mass production. (Using a scanning force microscope, you can push around atoms and build a single transistor, but not a whole chip)
This means, though we can already build a transistor in 1nm technology, we should not expect it to replace the current 28nm (?) nor the future 5nm directly.
  • \$\begingroup\$ The current process is 14nm, and by current it is only just starting to be adopted, such as in the Broadwell processors and some SoC's. 22nm being it's predecessor and widely used by Intel (Ivy Bridge) among others. Part of the issue is designing a working transistor with low enough leakages and high enough performance. As the gate and channel lengths become smaller, leakage currents go up and your transistors become unusable. Essentially the gate oxide thickness scales with size, so even though you have a length of 5nm or 1nm (5-25 atoms), your gate oxide is much thinner, so maybe 1-5 atoms! \$\endgroup\$ – Tom Carpenter Mar 30 '15 at 12:48
