I'm given a task to design a 4-bit register using D Flip-Flops (and MUXes) that operates according to the following selection inputs:
When..
S1S0 = 00, No Change;
S1S0 = 01, Register is Cleared to 0;
S1S0 = 10, Current State is Complemented;
S1S0 = 11, Parallel Data is Loaded.
Below is what I've made, but I'm not so sure if I've implemented it correctly.
Could you correct me if there's anything that's incorrect or that I should improve?
The circuit you implemented will work properly for all the cases you stated except for the last one. For S1S0 = 11, it will perform shifting and serial data loading.
For parallel data loading, you must connect the I_3 lines of your MUX to the parallel-data-in lines (4-bit).
Image courtesy: @IANIK
| improve this answer | |
  • \$\begingroup\$ So, is it how I do parallel loading? s22.postimg.org/ik2ucou3l/Untitled.png \$\endgroup\$ – IANIK Mar 30 '15 at 9:56
  • \$\begingroup\$ @IANIK Yes. And I am adding your picture to the answer. \$\endgroup\$ – nidhin Mar 30 '15 at 10:06
