For completeness, you can work out that the errors are related to interrupts by the fact that the function names being referenced in the error are __vector_(n)
, these refer to specific interrupt vectors. To find out exactly which ones you have to refer to the vector table in the AVR datasheet. Just to be awkward, in the compiled code the vectors are 0 indexed but in the datasheet they are 1 indexed, so to identify the correct vector, add 1 to the (n)
in the error message and look it up in the datasheet.
For the ATMega644(P):
__vector_15 is ISR(TIMER1_OVF_vect)
__vector_12 is ISR(TIMER1_CAPT_vect)
So they are vectors for Timer 1 Overflow and Input Capture. I believe in the standard Arduino Core, this is unused, but in the Wiring S core it must already be used by something.
The good news is that the ATMega1284(p) will work with the standard Arduino core, though unofficially. As the 644(p) is from the same series, just an earlier one, the Arduino core should work without modification with the 644. The only two things that are required are:
- A Boards.txt entry
- A pins_arduino.h file
By creating these entries, you should be able to compile code for the WiringS board using the standard Arduino IDE and core (for which the library was designed).
For the boards.txt entry, the following should work:
wiring_s.name=Wiring S @ 16 MHz
wiring_s.upload.tool=avrdude
wiring_s.upload.protocol=wiring
wiring_s.upload.maximum_size=63488
wiring_s.upload.maximum_data_size=4096
wiring_s.upload.speed=115200
wiring_s.bootloader.tool=avrdude
wiring_s.bootloader.low_fuses=0xF7
wiring_s.bootloader.high_fuses=0xD4
wiring_s.bootloader.extended_fuses=0xFD
wiring_s.bootloader.unlock_bits=0x3F
wiring_s.bootloader.lock_bits=0x2F
wiring_s.bootloader.file=Wiring/WiringBoot_WiringS.hex
wiring_s.build.mcu=atmega644p
wiring_s.build.f_cpu=16000000L
wiring_s.build.board=AVR_WIRINGS
wiring_s.build.core=arduino
wiring_s.build.variant=wirings
For the pins_arduino.h file, create a 'wirings' folder inside the 'variants' folder of the Arduino core, then create a pins_arduino.h file with the following contents:
#ifndef Pins_Arduino_h
#define Pins_Arduino_h
#include <avr/pgmspace.h>
// ATMEL ATMEGA644/644P
// (D 16) PB0 1 | | 40 PA0 (D 24) AI 0
// (D 17) PB1 2 | | 39 PA1 (D 25) AI 1
// INT2 (D 18) PB2 3 | | 38 PA2 (D 26) AI 2
// PWM (D 19) PB3 4 | | 37 PA3 (D 27) AI 3
// PWM/SS (D 20) PB4 5 | | 36 PA4 (D 28) AI 4
// MOSI (D 21) PB5 6 | | 35 PA5 (D 29) AI 5
// PWM/MISO (D 22) PB6 7 | | 34 PA6 (D 30) AI 6
// PWM/SCK (D 23) PB7 8 | | 33 PA7 (D 31) AI 7
// RST 9 | | 32 AREF
// VCC 10 | | 31 GND
// GND 11 | | 30 AVCC
// XTAL2 12 | | 29 PC7 (D 15)
// XTAL1 13 | | 28 PC6 (D 14)
// RX0 (D 0) PD0 14 | | 27 PC5 (D 13) TDI
// TX0 (D 1) PD1 15 | | 26 PC4 (D 12) TDO
// INT0 RX1 (D 2) PD2 16 | | 25 PC3 (D 11) TMS
// INT1 TX1 (D 3) PD3 17 | | 24 PC2 (D 10) TCK
// PWM (D 4) PD4 18 | | 23 PC1 (D 9) SDA
// PWM (D 5) PD5 19 | | 22 PC0 (D 8) SCL
// PWM (D 6) PD6 20 | | 21 PD7 (D 7) PWM
#define NUM_DIGITAL_PINS 32
#define NUM_ANALOG_INPUTS 8
#define analogInputToDigitalPin(p) ((p < 8) ? (p) + 24 : -1)
#define digitalPinHasPWM(p) ((p) == 4 || (p) == 5 || (p) == 6 || (p) == 7 || (p) == 19 || (p) == 20 || (p) == 22 || (p) == 23)
#define digitalPinToAnalogPin(p) ( (p) >= 24 && (p) <= 31 ? (p) - 24 : -1 )
#define analogPinToChannel(p) ( (p) < NUM_ANALOG_INPUTS ? (p) : -1)
static const uint8_t SS = 20;
static const uint8_t MOSI = 21;
static const uint8_t MISO = 22;
static const uint8_t SCK = 23;
static const uint8_t SDA = 9;
static const uint8_t SCL = 8;
static const uint8_t LED = 15;
static const uint8_t A0 = 24;
static const uint8_t A1 = 25;
static const uint8_t A2 = 26;
static const uint8_t A3 = 27;
static const uint8_t A4 = 28;
static const uint8_t A5 = 29;
static const uint8_t A6 = 30;
static const uint8_t A7 = 31;
#ifdef ARDUINO_MAIN
// these arrays map port names (e.g. port B) to the
// appropriate addresses for various functions (e.g. reading
// and writing)
const uint16_t PROGMEM port_to_mode_PGM[] =
NOT_A_PORT,
(uint16_t) &DDRA,
(uint16_t) &DDRB,
(uint16_t) &DDRC,
(uint16_t) &DDRD,
const uint16_t PROGMEM port_to_output_PGM[] =
NOT_A_PORT,
(uint16_t) &PORTA,
(uint16_t) &PORTB,
(uint16_t) &PORTC,
(uint16_t) &PORTD,
const uint16_t PROGMEM port_to_input_PGM[] =
NOT_A_PORT,
(uint16_t) &PINA,
(uint16_t) &PINB,
(uint16_t) &PINC,
(uint16_t) &PIND,
const uint8_t PROGMEM digital_pin_to_port_PGM[NUM_DIGITAL_PINS] =
PD, // D0
PD, // D1
PD, // D2
PD, // D3
PD, // D4
PD, // D5
PD, // D6
PD, // D7
PC, // D8
PC, // D9
PC, // D10
PC, // D11
PC, // D12
PC, // D13
PC, // D14
PC, // D15
PB, // D16
PB, // D17
PB, // D18
PB, // D19
PB, // D20
PB, // D21
PB, // D22
PB, // D23
PA, // D24
PA, // D25
PA, // D26
PA, // D27
PA, // D28
PA, // D29
PA, // D30
PA, // D31
const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[NUM_DIGITAL_PINS] =
_BV(0), // D0 PD0
_BV(1), // D1 PD1
_BV(2), // D2 PD2
_BV(3), // D3 PD3
_BV(4), // D4 PD4
_BV(5), // D5 PD5
_BV(6), // D6 PD6
_BV(7), // D7 PD7
_BV(0), // D8 PC0
_BV(1), // D9 PC1
_BV(2), // D10 PC2
_BV(3), // D11 PC3
_BV(4), // D12 PC4
_BV(5), // D13 PC5
_BV(6), // D14 PC6
_BV(7), // D15 PC7
_BV(0), // D16 PB0
_BV(1), // D17 PB1
_BV(2), // D18 PB2
_BV(3), // D19 PB3
_BV(4), // D20 PB4
_BV(5), // D21 PB5
_BV(6), // D22 PB6
_BV(7), // D23 PB7
_BV(0), // D24 PA0
_BV(1), // D25 PA1
_BV(2), // D26 PA2
_BV(3), // D27 PA3
_BV(4), // D28 PA4
_BV(5), // D29 PA5
_BV(6), // D30 PA6
_BV(7), // D31 PA7
const uint8_t PROGMEM digital_pin_to_timer_PGM[NUM_DIGITAL_PINS] =
NOT_ON_TIMER, // D0 PD0
NOT_ON_TIMER, // D1 PD1
NOT_ON_TIMER, // D2 PD2
NOT_ON_TIMER, // D3 PD3
TIMER1B, // D4 PD4
TIMER1A, // D5 PD5
TIMER2B, // D6 PD6
TIMER2A, // D7 PD7
NOT_ON_TIMER, // D8 PC0
NOT_ON_TIMER, // D9 PC1
NOT_ON_TIMER, // D10 PC2
NOT_ON_TIMER, // D11 PC3
NOT_ON_TIMER, // D12 PC4
NOT_ON_TIMER, // D13 PC5
NOT_ON_TIMER, // D14 PC6
NOT_ON_TIMER, // D15 PC7
NOT_ON_TIMER, // D16 PB0
NOT_ON_TIMER, // D17 PB1
NOT_ON_TIMER, // D18 PB2
TIMER0A, // D19 PB3
TIMER0B, // D20 PB4
NOT_ON_TIMER, // D21 PB5
NOT_ON_TIMER, // D22 PB6
NOT_ON_TIMER, // D23 PB7
NOT_ON_TIMER, // D24 PA0
NOT_ON_TIMER, // D25 PA1
NOT_ON_TIMER, // D26 PA2
NOT_ON_TIMER, // D27 PA3
NOT_ON_TIMER, // D28 PA4
NOT_ON_TIMER, // D29 PA5
NOT_ON_TIMER, // D30 PA6
NOT_ON_TIMER, // D31 PA7
#endif // ARDUINO_MAIN
#endif // Pins_Arduino_h
__vector_15
isISR(TIMER1_OVF_vect)
and__vector_12
isISR(TIMER1_CAPT_vect)
\$\endgroup\$wiring_s.build.variant=standard
to be something likewiring_s.build.variant=wirings
, then you will need to add a 'wirings' folder into the variants folder of the Arduino core, adding a suitable pins_arduino.h file to match the 644p. This file is for the 1284 which is pretty much the same, so should prove a good starting point: astroeq.co.uk/FileDump/pins_arduino.h You can either use that directly and just work out which digital pin number corresponds with the wiring S board, or update the numbering to match. \$\endgroup\$
