I probably need help more with terminology (and thus, how to find the answer that already exists) than with technology.
My current hobby project is a low-power device — max current is 100mA at 5V* — which is intended to be a pneumatic water level sensor. The basic operation is to drive a small air pump for a very brief period (about 200ms), wait a moment, then read the pressure, repeating these steps until subsequent pressure readings differ by less than the error margin of the pressure sensor.
The catch is that there is so little current available that the pump sometimes stalls at that tipping point between poles. It's a 6V rated motor which I've successfully driven at voltages as low as 3V. At 5V it draws about 150mA when running (measured on a slow-sampling multimeter).
Being naive and still young enough to know everything, I'm thinking of adding a largish capacitor between the power rails, with a resistor in series to charge it up. For example I might use 100µF with 1kΩ, which at 5V should keep the charging current below 50mA, more than enough to keep the power supply happy. Then "crowbar" the resistor out with a FET that is turned on when the pump needs to be driven (not that "crowbar" is a term that really applies to currents in the order of 100mA).
I probably need some other kind of device (maybe a P-channel FET?) for the crowbar, since it's going to be turned "on" by bringing the gate voltage from below the source up to the same as the drain (Vgs will either be negative or zero):
My main question is: what is the terminology for this kind of setup where I'm intentionally catering to the high current inrush of the pump motor with a power supply that can't deliver that current?
Secondary questions: is what I'm doing in any way "normal" or sensible? Are there some references I should read up on before proceeding further with this project?
- the power supply is a solar LiPo charger with a USB 1.0 output, so 5V at a maximum of 100mA.
