Having a lot of trouble working through an AC circuit, asking for some help.
The circuit is relatively simple - I have a capacitor of capacitance \$C\$ and resistor of resistance \$R\$ hooked in parallel, which is hooked in series with a coil loop of impedance \$L\$ to an alternating voltage source of \$e_0\sin(\omega t)\$.
I'll work through the steps to show you where I'm having my problems.
So, first, solving the parallel combination. $$ \frac{1}{Z_t} = \frac{1}{Z_c} + \frac{1}{Z_r} $$
and we know that \$Z_c = \frac{-i}{\omega C} \$ and \$Z_r = R \$
So $$ \frac{1}{Z_t} = \frac{1}{R} - \frac{\omega C}{i} = \frac{1}{R} + \omega Ci $$
and thus $$ Z_t = \frac{R}{1+i \omega CR} $$
Now, to find the total impedance, \$ Z = Z_t + Z_l \$
$$ Z = \frac{R}{1+i \omega cR} + i \omega L = \frac{R(1- \omega^2 LCR) + i \omega L}{1+i \omega CR}$$
Is that right?
Additionally, the next problem I then have is the phase shift. By definition, the phase shift of a complex circuit is $$ \phi = \arctan\left(\frac{\text{Imaginary}}{\text{Real}}\right)$$
How the heck am I supposed to get an imaginary and a real out of that equation? What parts are imaginary and what are real?
Assuming this equation is correct: $$Z = \frac{R}{1+i \omega cR} + i \omega L$$
We multiply the first term's nominator and the denominator by the complex conjugate of the denominator: $$.. = \frac{R(1-i\omega c R)}{(1+i \omega cR)(1-i\omega c R)} + i \omega L$$ and thus getting rid of imaginary stuff in the denominator: $$.. = \frac{R(1-i\omega c R)}{(1+ \omega^2 c^2R^2)} + i \omega L$$ And this thing is easily separated to real and imaginary parts: $$.. = \frac{R}{1+ \omega^2 c^2R^2} + i \left(\omega L - \frac{\omega c R^2}{1+ \omega^2 c^2R^2} \right)$$
Easiest method to get the overall phase angle is:
Phi = (phase angle of numerator) - (phase angle of denominator)
Phi = arctan[wL/R(1-w^2LCR)] - arctan(wCR)
This saves a lot of algebra.
Generally, if you have a complex impedance, Z, in the form: Z = (A+jB)/(C+jD), the best way to get modulus (or 'magnitude') and phase angle is:
Magnitude = SQRT(A^2 + B^2)/SQRT(C^2 + D^2)
Phase angle = arctan(B/A) - arctan(D/C)
(Note, in engineering we use 'j' as the imaginary operator, since 'i' is reserved for current)
