I have an Arduino mini pro with a 433mhz receiver attached. I connected this to my computer via a usb to serial cable. I've tried it on two laptops ans it works fine with it (>15 metres), but when connecting it to the Raspberry pi the range is REALLY bad (<1 metre).
I measured the voltage at the 433mhz receiver and it was slightly lower when it was connected to the raspberry pi. I tried to rule this add by adding a voltage booster circuit but it made it worst if anything.
laptop = 4.88v raspberry pi = 4.3v raspberry pi using booster circuit = 4.98v
I've not tried an external power supply yet.
Any thoughts on what might be causing the problem?
Thank you in advance!
  • \$\begingroup\$ How about naming the parts and a circuit diagram with links to the receiver data sheet. It's too generic at the moment. BTW it's "MHz" not "Mhz" or "mhz" \$\endgroup\$
    Apr 6, 2015 at 20:47
I connected up an external power supply to the receiver instead of using the power coming from the Raspberry Pi / Arduino. This made an amazing difference to the range.
For the receiver module I was working with 5.5V - 6V seemed to give the best range. Anything below 5V was pathetic.
