In my job I came across reading a customer schematic. I am facing trouble in identifying the marked part of the schematic, which is connected at the pins of uUSB Interface Controller.
It seems like a fuse but not very sure of the symbol, as its confidential, unfortunately the engineer did not give a part name also. Any way, it doesn't effect the design but I am eager to know about it out of interest.
The design is of a mobile phone.
Schematic containing the unknown symbol
    \$\begingroup\$ Maybe a ferrit bead, I am not sure. \$\endgroup\$ Commented Apr 7, 2015 at 11:31
  • \$\begingroup\$ I honestly have no idea. Maybe ask the designer? \$\endgroup\$
    – Dzarda
    Commented Apr 7, 2015 at 11:36
  • \$\begingroup\$ Can you share the part number of the IC with the BOOT and JIG pin? \$\endgroup\$ Commented Apr 7, 2015 at 11:53
  • \$\begingroup\$ @BattleHamster its SM5504, any way you will not find even if you google. as its confidential. kindly let me know if you did :) \$\endgroup\$
    – kakeh
    Commented Apr 7, 2015 at 11:59
    \$\begingroup\$ I have to guess as well. But for me it looks like a removable part of the wire (I usualy use a 0R resistor for that) \$\endgroup\$
    – Botnic
    Commented Apr 7, 2015 at 13:11
It does not get the same signal i.e JIG_ON_N.
Actually it is shutdown or reset button that requires a short push (push button) that is short this two wires. Search on Eagle
Some times, schematic editor softwares using strange symbols that are not standard for industry.
