I am in the middle of making my own ROV with six DC motors as the thrusters.
The main controller inside the ROV is a microcontroller that is connected to Raspberry Pi that can send and receive control command over TCP. Power and control from-and-to the surface is established using tether cable which consists of power cable and Cat-5 cable for ethernet connection. The power transmitted is 36V with maximum current rating of 20A. Inside the ROV, the transmission voltage is converted to 12V for motor usage and 5V for other electronics (microcontrollers, Raspberry Pi, other sensors).
The problem is every time I start the motor, Raspberry Pi seems to be browning-out (flickering power indicator) and then turned off. I have tried using separate source (e.g. battery) for the 5V devices and it works seamlessly.
Do you guys have any solution to this? I have thought about using optocoupler, but then again the power came from the same source (tether cable) so I thought it will result in the same way. The best that I can think of right now is to find isolated DC-DC converter for the Raspberry Pi.
Thanks!
Edit: I made my own driver, which consists of a single NPN transistor (TIP142) acting as a switch. The motor will draw around 7A To convert 36V to 12V, I use this http://www.ebay.com/itm/DC72V-36V-48V-60V-to-12V-240W-16-20A-converter-Electric-Storage-Battery-car-/221381653107?pt=LH_DefaultDomain_0&hash=item338b5ff273. As for the 12V to 5V converter, I 'm using Turnigy UBEC 5A
    \$\begingroup\$ Can you add a schematic with part numbers of regulators/converters/drivers used? Also can you tell us what each motor will draw from the source? \$\endgroup\$
    – Dan
    Apr 10, 2015 at 5:58
    \$\begingroup\$ Depending on conditions, this kind of brownout is best fixed by using a capacitor to give the 5v rail some ride through, and a diode to make sure the motor doesn't steal it. \$\endgroup\$
    – user39962
    Apr 10, 2015 at 6:07
  • \$\begingroup\$ Hah, @SeanBoddy I used the word Steal in a design report at school 20 years ago, in exactly the same context. The Prof underlined it in red, saying it wasn't appropriate technical language! \$\endgroup\$
    – tomnexus
    Apr 10, 2015 at 10:53
  • \$\begingroup\$ @tomnexus - motor be comin to steal yo trons, foo. \$\endgroup\$
    – user39962
    Apr 10, 2015 at 23:31
  • \$\begingroup\$ Turn on power, measure voltage at tether and rov. DMM is fine, scope better. Activate motor, repeat. If I am correct, you will see significant voltage drop (especially at locked rotor current - start up). \$\endgroup\$ Apr 20, 2015 at 15:40
The problem you are experiencing is due to the resistance of your umbilical. You have a transmission line. The \$I^2 R_{Cable}\$ losses are eating up your power.
Measure the voltage and current at the terminals of your motor. As I increases \$V_{Load}\$ will decrease.
There might be enough voltage to start at no-load (especially if rov is out of water - pushing air) but as current increases, voltage drop to wire increases, which explains your observed characteristics.
Solution would be to send ac at a higher voltage to rov, step it down in the rov and drive motors.
Edit... Or increase the gage of your power feeder cable as suggested by: Tether - Power and Voltage Drop Examples.
It really depends on your current. 6 motors can draw a lot especially going from locked rotor to full speed. 20A is a lot depending on length of your umbilical.
Look up resistance of wire from AWG (American Wire Gage). They have R/100ft. Multiply it by your tether length * 2 / 100ft.
The 2 is because you have to get current to load and back. Think about number of pins on a lamp.
Or you can also calculate resistance. $$R_{Cable} = \frac{ρ l}{A}$$ ρ = 10.37 Ω CM/ft, l = 2 * length of your umbilical, A in CM from AWG.
$$V_{DROP} = I R_{Cable}$$
Components of an ROV system
  • \$\begingroup\$ What is an "Ω CM/ft"? \$\endgroup\$
    – Transistor
    Aug 30, 2016 at 17:10
  • \$\begingroup\$ American unit for resistivity. Metric in Ω m. \$\endgroup\$ Aug 30, 2016 at 17:21
The easiest way to troubleshoot this problem is to add an internal battery to power the Pi and anything else that might be affected by a brownout. Make sure that the ground wires are connected appropriately.
In other words, simply move the +DC wire that feeds the Pi and other stuff away from your tether power supply and connect it to a battery of the appropriate voltage.
You can then troubleshoot the problem, looking for ground-related problems (ground bounce), voltage sag from the tether power supply, etc.
You will want to use a DSO to capture any sags.
DC-DC converter, especially if it's a buck-boost type, seems like a good idea. If your internal grounding is suitably "star" shaped then I wouldn't expect too many problems with return current and therefore it may not be necessary to isolate it.
You could try the usual EMC solutions: Pi in a metal box, ferrite chokes on its power and data leads.
You could also add more capacitors to the Pi power supply to smooth glitches.
If you have an internal datalogging/telemetry system for things like system temperature, add "tether voltage" to it so you can assess the impact of running the motor.
