6
So I have a circuit where I need the current consumption to be low. Therefore I am using a 10M\$\Omega\$ resistor to 'pull-up' the pin on a chip which will need to be switched between high and ground (by high I mean the supply voltage which is ~3V).
In order to pull this pin down to ground when necessary I have a BJT (BC847C) which will be triggered by a microcontroller in order to bring this pin down to ground. The problem is, this doesn't seem to be working. Therefore I am wondering if there is any leakage current through the collector and emitter junction of the NPN which would be creating a voltage drop over the 10M\$\Omega\$?
The circuit really needs to be low power (in the tens of \$\mu\$A's) hence the need for large resistors as it will be on all the time (there are two switches that are being controlled by this set up and I need to switch between them)
6
Let's have a look at the datasheet:
At room temperature the maximum leakage is 15nA at 30V, implying a 150mV voltage. It will be less at 3V, but not necessarily proportionally less. The maximum leakage at a Tj of 150°C is 5uA which would be excessive. So, how much of that is because they don't want to make time consuming low-current tests on an inexpensive part? Here's a typical curve from a similar part (2N4401) which shows you might typically run into trouble around 100°C Tj (50nA).
It's usually considered bad engineering to depend on typical values (though you see it done with careful forethought all the time in many commercial products), but I have to conclude that it is unlikely (approximately zero percent likelihood) that ICBO leakage is causing the problems in your setup.
Note that this is the leakage with Vbe ~=0. If you leave the base open or (worse) have it connected to something that acts as an antenna, all bets are off. As Dave Tweed points out the gain of the transistor can amplify the current if you leave the base open. It could conceivably have a gain of 100 at 1nA Ib. So, don't do that! Make sure there is a resistance from base to emitter when you want the transistor 'off'. Even 1M from base to emitter is enough to make that problem go away- more likely you're driving it from a push-pull output and it will have a very low resistance to keep the ICBO current from being amplified.
  • \$\begingroup\$ I think I can largely follow the reasoning behind both David's and Spehro's answers, but I am curious about the two different opinions about slightly different approaching of problem. Could I tempt you both to respond the the other answer? \$\endgroup\$
    – jippie
    Apr 10, 2015 at 19:31
    \$\begingroup\$ If the OP drives the port pin high-Z rather than low when the transistor is supposed to be off, he gets the situation in David's answer because the base can amplify the collector-base leakage current. If it is actively driven low with a reasonable value base resistor (1M or less) then the leakage almost surely isn't what's causing his current problem-the base resistor sucks the nA leakage current away so Vbe is too low to get any significant base current or hFE- IOW you get nA or pA, not hFE times nA. \$\endgroup\$ Apr 10, 2015 at 20:14
Interesting question; the data sheet doesn't actually say.
Note that this transistor has very high gain, especially at low collector current values — the "C" variation has an \$h_{FE}\$ of over 500! This means that at a collector current of 0.3 µA, it only takes a base current of about 1 nA to saturate it, and this is much smaller than the specified base-emitter leakage current (IEBO = 100 nA).
I'd say that at these current levels, a BJT is probably not your best choice. Consider using a low-leakage MOSFET instead.
  • \$\begingroup\$ I think I can largely follow the reasoning behind both David's and Spehro's answers, but I am curious about the two different opinions about somewhat different approach to the problem. Could I tempt you both to respond the the other answer? \$\endgroup\$
    – jippie
    \$\begingroup\$ Link seems broken \$\endgroup\$
    – kimstik
    Oct 6, 2020 at 8:16
