I've built a current sense differential amplifier that measures the voltage across a 1 Ohm resistor, to give me a reading for the current through it.
I've connected it as follows, all resistors are matched 10k to give a gain of 1:
(Image source: Electronics Tutorials)
I am powering it from a single rail 12 volt source. The problem is even though this is a rail to rail opamp (Output Low swing from 5-20mV) I'm getting a constant error of 0.62V and it seems the opamp is not able to go below this value.
I have tried to resolve this by connected Vout to ground using a 10k resistor, but that makes no difference whatsoever.
I tried it with dual supply configuration (+8V, -8V) and that seems to resolve the issue. However I want to run this off a single supply rail, so this is not a viable option.
How can I resolve this? I'm trying to measure the voltage drop across a 1 ohm resistor to give me a reading for current through the circuit (0-1V represents 0-1 A) so I can set up a current limit. A better way (or practice) to doing this is also welcomed. The initial (but not ideal) fix I can think of, is to offset the readings by a few volts?
Edit:
Changed R1-R4 from 10k to 100k and I'm down to about 30-50mV!
