I need to add a 1K ohm resistor to a HDMI connector to solve some EDID HDMI issues.
Here is the image of the person who already did that.
HDMI connector
My quesion is: Considering that voltage of pins to connect to resistor is 5V and amperage is (perhaps) 50mA; resistor 1k ohm of what wattage should I purchase? 1/4W, 1/2W, ... ?
Thank you.
EDIT:
I don't know why they suggest to shortcut those pins in that article...
If I will use 1000ohm; with 5V voltage => 5mA will flow through resistor? The power will be 0.025W.
If I will use 1/4W resistor, it will not overheat, right? 1/4W is max value of that specific resistor to work with NO overheat?
article
You can't get 10mA at 5VDC through a 1k resistor. You can get max of 5mA (5V / 1000ohm = 0.005A) Power is I^2 * R: 0.005 * 0.005 * 1000 = 0.025W
You need a minimum of 1/40 of a watt.
Commenters are correct, I meant minimum, not maximum, but I'm fuzzyheaded sometimes :) Thank you Commenters!
  • \$\begingroup\$ I'm happy to upvote if you mention 'resistor with minimum power rating of 1/40 Watt' or similar. \$\endgroup\$
    – jippie
    Apr 10 '15 at 19:19
  • \$\begingroup\$ @R Drast: That should be minimum 1/40 watt - higher power rating is fine. \$\endgroup\$ Apr 10 '15 at 19:28
  • \$\begingroup\$ I don't know why they suggest to shortcut those pins in that article... If I will use 1000ohm; with 5V voltage => 5mA will flow through resistor? The power will be 0.025W. If I will use 1/4W resistor, it will not overheat, right? 1/4W is max value of that specific resistor to work with NO overheat? \$\endgroup\$
    – ihtus
    Apr 10 '15 at 19:37
P = IV. P is power on watts. Get that wattage or higher resistor.
    \$\begingroup\$ I think you mean P=I^2R, or P=E^2/R. P=VR would mean he needs a 5000 watt resistor. \$\endgroup\$
    – R Drast
    Apr 10 '15 at 19:12
  • \$\begingroup\$ @RDrast 5000W resistor would work too ;o) (not accounting for frequency behavior of an actual 5kW resistor) \$\endgroup\$
    – jippie
    Apr 10 '15 at 19:18
  • \$\begingroup\$ Meant V × I not R \$\endgroup\$
    – Passerby
    Apr 10 '15 at 20:31
