My module has search for specific value at RAM and then return its location address. when I wrote a test bench, I see that the module didn't work correctly! always the output value is "don't care". Although I have initialized the memory.
Search module>>>
module Search (
    clk,
    rst,
    SearchData,
    FindAddress,
         StopSearch
input           clk;
input           rst;
input[7:0]      SearchData;
output reg [1:0]   FindAddress;
output reg StopSearch;
integer i,x;
wire read_rq;
reg [1:0] nxt_address;
reg [2:0] ii;
initial
begin nxt_address=0;i=0; ii=0; end
wire[7:0] read_data_inx;
D0_RAM1 D0(
    .clk(clk),
    .rst(rst),
    .read_rq(read_rq),
    .write_rq(0),
    .rw_address(nxt_address),
    .write_data(0),
    .read_data(read_data_inx)
always @(posedge clk )
begin
        for ( x =0 ;x <4;x=x+1) begin
                if (read_data_inx == SearchData)  begin //master i has priority
                        FindAddress <= nxt_address;
                        StopSearch <=1;
      end
                nxt_address <= nxt_address+1;
        end
end
the RAM module:
module D0_RAM1(
    clk,
    rst,
    read_rq,
    write_rq,
    rw_address,
    write_data,
    read_data
input           clk;
input           rst;
input           read_rq;
input           write_rq;
input[1:0]      rw_address; //2 bit
input[7:0]      write_data;
output[7:0]     read_data;
reg[7:0]     read_data;
reg[3:0] count_;
integer out, i;
// Declare memory 2^2 x8 bits
// 2^2 = 4
reg [7:0] memory_ram_d [3:0];
reg [7:0] memory_ram_q [3:0];
initial
begin
count_=0;
        for (i=0;i<4; i=i+1) begin
        memory_ram_q[i] <= i;
                  memory_ram_d[i] <=i;
                  count_=count_+1;
                  end
end
---> Any ideas?
Thanks.
  • \$\begingroup\$ What is the purpose of the for loop in the Search module? It looks like the calculation is exactly the same for every value of x. \$\endgroup\$ – The Photon Apr 10 '15 at 20:15
    \$\begingroup\$ I think your fundamental issue is that you're trying to use your programming experience for Verilog logic design. Verilog is not a programming language, it's a hardware description language. You need to un-learn your programming habits to be able to master Verilog. \$\endgroup\$ – The Photon Apr 10 '15 at 20:22
  • \$\begingroup\$ purpose of the for loop is to check all memory locations \$\endgroup\$ – H.H Apr 10 '15 at 20:24
  • \$\begingroup\$ You probably want to check one memory location on each clock cycle. Not try to check them all in a single clock period. \$\endgroup\$ – The Photon Apr 10 '15 at 20:32
  • \$\begingroup\$ Remember that for loops in Verilog unroll into hardware circuits that operates in parallel. So you are generating 4 separate circuits that all try to access the RAM at the same time. \$\endgroup\$ – The Photon Apr 10 '15 at 20:39
A physical memory has a fixed number of read (and write) ports. If you want to search for a value inside the RAM, you would need to read every entry. So either you have enough ports to read them all in parallel, or you need to iterate using the read ports you have over multiple cycles.
Really, you need to google CAM (content-addressable memory), that's what you are trying to build, and they are not built from standard memory blocks.
Among other issues in your code: your memory doesn't seem to actually respond to read requests (nothing is driving read_data), so no wonder you get don't care results.
| improve this answer | |
