I have this circuit which I have to solve for Io using nodal analysis. Everything seems easy but I am confused about the nodal equation for V2 given below in the solution. They seemed to ignore the part of the node that goes from V2 to ground, through the 2 1-ohm resistors? In other words, shouldn't there be another term that looks like: $$\frac {V_2}{2}$$
Can you please clarify this? Thank you.
