19
I just came from the local library, it’s quite big, and most of it is made of an architectural design using mostly painted metal book shelves painted with some kind of anticorrosive paint along with glass floor all over the place, everything was fine and nice, until I started to get static electricity shocks around every single book shelf (yes the painted ones) in every floor almost all the time I took around 13 shocks in less than 20 min
As you can see most of the metal structure it’s joined by huge bolts (screws) so there is continuity all over the place (I checked) also there is a possibility to the metal structure to be joined to the structural studs of the building
I’m trying to find out how is it possible to "fix" something of this magnitude As an antecedent I installed an antistatic mat in my own home lab, along with the nonexistent at the time grounding rod and wiring across all the home, I do know antistatic mats have a huge impedance that “slows” the flow of current to mains earth while it discharges the body slowly to protect electronics of voltage differences between the desk, user and electronics, being at the same potential, like in the following picture
My theory for the library is that the users being insulated of earth and by being walking around a glass floor, are generating static electricity just by walking with their clothes on, the electrons find no way to discharge around the glass and as soon as they touch any metal book shelve they get discharged, there’s a chance of the system being grounded to mains earth, but as I recall a door knob can shock you like this even by not being grounded so I’m not sure, and a bit confused now
I’m thinking on several ways to solve this
1) The first idea that came to my mind was to to an arragement like an antistatic mat, add a 10MOhms power resistor to join the book shelves in several points to mains earth, this “might” slow the current flow of electrons and no shocks will be sensed, however my common sense tells me that the mat itsle fhas a high impedance unlike the book shelve, this might work to slow the flow across the resistor but it would make nothing for the user that will still get shocked due to the low resistance of the metal book shelves and THEN it will be slowed down across the resistor
2) Second I thought of painting the shelves but then I noticed they were already painted and the shock were happening even above the painting
3) I thought about looking for the bounding point to mains earth and, leave the metal structure as a “floating circuit” with no connection to mains earth, but this might get complicated since as i said before the metal structure might be touching the internal building structure
And from all this possible solutions, several questions arise,
  • a) Can static shocks occur from grounded and ungrounded metals?
  • b) How do you prevent getting zapped when everything around you is metal and glass floors?
  • c) What is the worst case scenario if I unbound the metal structure from mains earth? (Not contacts, nor lighting rods, just make sure to leave the metal book shelves ungrounded), will the user still get shocked?
    \$\begingroup\$ Triboelectric effect is very likely what's generating the voltage -- this is more noticable in dry air. See this answer: electronics.stackexchange.com/questions/26956/… \$\endgroup\$
    – MarkU
    Apr 11, 2015 at 1:27
    \$\begingroup\$ I think the root cause of the static discharge problem is the glass floors, because glass is near the positive extreme end of the triboelectric series, and typical shoes have rubber soles -- a material near the opposite end of the triboelectric series. \$\endgroup\$
    – MarkU
    Apr 11, 2015 at 1:32
    \$\begingroup\$ Unrelated, but that is an amazing looking library. Wow. \$\endgroup\$
    – efox29
    Apr 11, 2015 at 2:52
    \$\begingroup\$ You can get a shock touching an ungrounded object, just by charging up that object. If it's something large like a shelf, its capacitance is so much more than a person's, it will make little difference if it's grounded or not. Try it out by touching a person that's not charged. \$\endgroup\$
    – tomnexus
    Apr 11, 2015 at 7:06
  • \$\begingroup\$ Try heel grounders / wear different shows / carry a 10 megOhm pencil. / Spray floor with conductive spray (sold for this purpose) / Shelves can still shock if floating. They form a largish capacitor to ground and also have substantial leakage paths to ground as area available is very large. | Reducing V generation probably profitable. \$\endgroup\$
    – Russell McMahon
    Apr 11, 2015 at 8:06
10
Yes. A large ungrounded object still has capacitance. If there is a higher density of electrons on you than on the object, the electrons on you will feel repulsion from the other electrons on you and want to jump to the object where they will have more room to spread out. (Same goes in reverse if there are more electrons on the object.)
Eventually if people keep transferring electrons to the large object, then the electrons will build up on the object until they push back as much as the electrons on you, and there will be no spark. The bigger the object, the more electrons it takes to "fill" it up to having the same density of electrons as there are on you. Grounding an object connects it to the earth, which is the biggest object around and so represents a practically infinite sized holder of electrons. You can keep charging yourself up and then discharging to the earth and never make a practical dent in its charge density.
You can either...
  1. Prevent yourself from accumulating a different density of charge relative to the metal building.
    a. Wear a pair of diamond soled shoes. Because this material much closer to glass on the Triboelectric Series, you will accumulate less charge while walking compared to the rubber soled shoes you are likely using now. Alternately, you can cover the soles of your existing shoes with a rich red acrylic coat.
    b. Keep yourself electrically connected to the metal at all times, possibly using a wrist strap that is tied into an overhead Pantograph system on the ceiling.
    c. Increase the humidity in the air inside the building, possibly by installing a large fountain or waterfall in the center of the atrium area. The humidity will help excess charge bleed off your body and therefore prevent you from accumulating enough to cause a spark between you and the metal.
  2. Prevent any charge you have already accumulated from making a spark and "zapping" you.
    a. Buy a conductive arc flash protective suit and wear it whenever you are in the building. The zap between your body and the metal is just a smaller version of the arcs that linemen and electricians deal with everyday, and this suit will keep the arc between the metal and the suit rather than your skin, so you should not feel it. Be sure to get the suit inspected and certified frequently.
    b. Get a hot stick. Anytime you approach a metal shelving unit, use the hot stick to equalize the charge between your body and the metal before touching it. There is still charge flowing between your body and the metal, but the high resistance slows that flow by reducing the current to levels that should not hurt.
    c. Evacuate the air inside the building. With no air, there would be no gas to ionize and therefore no arc to zap you. This would require hermetically sealing the building envelope and using a large pump to remove the air and maintain the vacuum. This might also require structural modifications as the forces generated by the external air pressure on the building surfaces can be quite large.
People would still get shocked until the metal was charged up. Once the metal was charged, it would still zap people who had not yet been charged themselves by walking on the floor yet. It would probably make sense to divide the building into a dozen or more zones of increasing charge, each completely electrically isolated from the others. The zone near the entrance would have the least amount of charge to accommodate people first entering the building who have not accumulated any charge yet from walking on the glass floors. The zone farthest from the entrance would be at full charge and would hold the physics textbooks.
    \$\begingroup\$ I thought 1c was a hilarious solution, and then I got to 2b. \$\endgroup\$ Apr 18, 2015 at 18:21
  • \$\begingroup\$ Awesome! We really do need more comments like this! \$\endgroup\$ Apr 18, 2015 at 19:36
    \$\begingroup\$ A nice side advantage of 2a is that when the police chase you as a suspected terrorist, you are immune to the tasers they will fire at you. \$\endgroup\$ Mar 20, 2017 at 14:08
A temporary fix for this problem is to spray the floors with something like Staticide. A dilute solution of fabric softener will also work - that would be something like Downy or Fleecy in North America.
You need to apply only a light misting of the liquid onto the surface.
A more permanent fix is to have the floors waxed with a static-dissipative wax. We use such a wax on the floors of our shop, lab and production areas and it works well. But it's a pain to apply correctly - there is a very specific cleaning and preparation process that you must follow if you want the wax to have a long lifetime.
You can also carry around something conductive, like a metal pen or something like that. And when you come to an object you know you're about to get shocked from, simply hold the conductive object in your hand and use it to touch the object you're about to be shocked from first. This will still cause a passage of electrons, but the spark will be at the end of the conductive object (metal pen, etc.), and you will not feel the shock.
  • \$\begingroup\$ I know the above answer doesn't solve the problem and it's not the best idea to tell all the visitors to carry around a metal pen but this is a temporary solution for you personally or for the maintenance workers and staff until you can permanently fix the problem. \$\endgroup\$ Mar 20, 2017 at 13:54
  • \$\begingroup\$ seems to have left the building now in 2020 but, for information - Based on experience - you still feel the shock in such cases but it's not so severe. The transition of charge to your body via your hand still occurs. Presumably the larger contact area lessens (but does not remove) the sensation. \$\endgroup\$
    – Russell McMahon
    Mar 4, 2020 at 1:07
