8
In discussion a friend mentioned:
In the original implementation of PAL and NTSC they used the AC current as a means providing the frequency for the TV. As the different mains had different frequencies, they designed the TV standard to have different frequencies.
I wasn't sure about this so I wanted to check.
My question is: Is the design decision for different frequencies in PAL and NTSC related to the AC mains power frequency?
10
Yes, it is related.
In early TV implementations, it was not easy to remove all of the AC line ripple from the DC power circuits that drove the CRT, and this resulted in a slight variation in intensity from top to bottom. It was found that if the vertical frequency of the TV signal was the same as the power line frequency, these intensity variations would appear in the same location on every vertical sweep, effectively causing them to "stand still" on the screen, and this was much less objectionable than having them drift up or down.
There are also sources of RF noise that are related to the power line frequency, and the visual artifacts caused by that kind of noise also stand still on the screen.
    \$\begingroup\$ Also, line sync freezes the picture distortion caused by magnetic fields from power conductors near the TV. \$\endgroup\$
    – tomnexus
    Apr 11, 2015 at 13:47
  • \$\begingroup\$ The "philosophy" is now synchronizing frames and lines to main, through a PLL circuitry for EU TV. \$\endgroup\$
    – user288518
    Jun 20, 2021 at 13:22
PAL and NTSC are colour encoding systems and are not necessarily related to horizontal and vertical scan frequencies.
The choice to make the vertical scan frequencies the same as the local power line frequency was to make the picture disturbance due to poor power supply filtering, and power current magnetic fields less obvious. With the power line frequency and vertical scan frequency the same, any such disturbance would be stationary on the screen, and so would be less noticable than if the disturbance was rolling through the screen, as would happen if the frequencies were different.
    \$\begingroup\$ Ever since NTSC color broadcasting standards have been adopted, the frame rate in no longer 30 frames (1/2 the line frequency) per second but rather 30/1.001 (approximately 29.97) frames per second, to reduce interference seen on B&W TV's between the color signal and the FM carrier for audio. \$\endgroup\$
    – tcrosley
    Apr 12, 2015 at 5:09
  • \$\begingroup\$ @tcrosley I always assumed the frequency was actually locked to the local line (for example, security cameras do this). Line frequency varies, but there are benefits to being locked during recording, and again being locked during playback on air. I suppose if it's a quartz clock, the beat would be very slow, tens of seconds, so might not be visible anyway. Do you know if it uses Line, or is internally generated now? \$\endgroup\$
    – tomnexus
    Apr 12, 2015 at 8:22
  • \$\begingroup\$ No, they don't use line frequency, because of the difference between 1/29.97 and 1/30 sec per frame. See this article about SMPTE drop frame timecode for more info. It is assumed the clocks for recording and playback are exactly the same frequency. In TV studios, timecode is generated by a master sync generator, tied to an atomic clock standard. Portable cameras may use time code generators using temperature-controlled crystals. A new development is to make use of GPS receivers since GPS signals are accurate to ±10 ns. \$\endgroup\$
    – tcrosley
    Apr 12, 2015 at 9:20
  • \$\begingroup\$ "I always assumed the frequency was actually locked to the local line (for example, security cameras do this)." I imagine security cameras just ignore the whole drop-frame issue since it was to ensure compatibility between B&W and color broadcasts. I assume security systems are either B&W or color and in any case, can run at 30 fps. \$\endgroup\$
    – tcrosley
    Apr 12, 2015 at 9:34
  • \$\begingroup\$ The first TV station I worked at had a master sync generator that did have provision to lock to the AC power line, but that was for monochrome use. Colour sync generators for NTSC were driven by a 14.31818 MHz crystal (four times the colour subcarrier frequency). I wouldn't be surprised if current sync generators are controlled by a GPS-locked frequency standard. I'd expect that colour security/closed circuit cameras would have 14.31818 MHz crystal oscillators (but that's just a guess). \$\endgroup\$ Apr 12, 2015 at 16:32
Dave Tweed's answer is largely correct. But it wasn't just AC ripple on the DC power circuits that caused the variation. The signal cicuits in early TV used tubes (a.k.a. valves). The cathodes usually had a heater filament that was often driven by low voltage AC (typically about 6 V). This caused the temperature of the cathode, and consequently the gain of the tube, to have some variation at twice the power line frequency (the heater power varies with the square of the AC voltage, hence the doubled frequeny).
  • \$\begingroup\$ But if that implies a 100 or 120Hz ripple, wouldn't that mean, e.g. a dark band across the middle of each 50 / 60Hz field, and two bright ones near the 1/4 and 3/4 levels (or vice versa... etc)? Still less objectionable than bands rolling / flickering any more rapidly than maybe once or twice per minute, but still very obvious and annoying. Seems like something that'd have to be fixed during the early development and engineering refinement of the receiver (and camera) hardware itself e.g. with an inverted and attenuated copy of the heater drive current to modulate the tube output... \$\endgroup\$
    – tahrey
    May 7, 2019 at 22:06
  • \$\begingroup\$ Like I doubt the idea of feedback driven voltage regulation would have been foreign to engineers even in the early days of electronics. The modern LM semiconductor regulator may miniaturise the necessary circuitry and make its setup easy, but the idea behind it is pretty well-worn. And, besides that, they already had capacitors... ((I mean... I'm not saying it wasn't the case as it sounds like you speak from experience... it just sounds rather unnecessary and avoidable even with tech of the time)) \$\endgroup\$
    – tahrey
    May 7, 2019 at 22:10
    \$\begingroup\$ The effect of the ripple on the heater filaments was effectively put through a low-pass filter by the thermal inertia of the heater coil, so it wasn't too bad. \$\endgroup\$ May 7, 2019 at 22:14
