I'm supposed to use nodal analysis.
Node A is the left one, node B is the middle one and node C is the right one. The bottom one is my reference node.
So I got these equations:
Node A: \$ -5 + \dfrac{V_a-V_b}{20} + \dfrac{V_a-V_c}{50} = 0 \$
Node B: \$ -\dfrac{V_a-V_b}{20} + \dfrac{V_b-V_c}{30} = 0 \$
Node C: \$ -\dfrac{V_b-V_c}{30} - 0.01V_1 - \dfrac{V_a-V_c}{50} = 0 \$
\$V_b = 0.4V_1\$
I tried solving the system with these equations but I didn't get anywhere.
What am I doing wrong?
The answer is: \$V_1 = 148.15 V\$
  • \$\begingroup\$ Is the equation derived from the VCVS Vb = 0.4V1 ? \$\endgroup\$ Commented Apr 11, 2015 at 15:49
  • \$\begingroup\$ Yes, sorry I missed that you already had that one written down. \$\endgroup\$
    – The Photon
    Commented Apr 11, 2015 at 22:53
\$V_b = 0.4V_1\$
You have four equations but only three unknowns, so you know you have a problem.
Also, your node B equation is incorrect because it doesn't account for current through the VCVS.
I would throw away the node B equation and use the other three.
  • \$\begingroup\$ If I used this wouldn't I have 4 unknowns? Node A: -5 + (Va-Vb)/20 + (Va-Vc)/50 = 0; Node C: -(Vb-Vc)/30 - 0.01V1 - (Va-Vc)/50 = 0; Vb = 0.4V1 \$\endgroup\$ Commented Apr 11, 2015 at 15:56
    \$\begingroup\$ @StefanBurnett, fourth equation: V1 = Va. \$\endgroup\$
    – The Photon
    Commented Apr 11, 2015 at 18:41
