My project is to deliver the output of 200w solar panel (40v,1.5A)- very low because I am using lamps instead of the sun- to a load at a voltage level of 100v, after implementing the design of my boost circuit (L of 4.4 mH, C of 220 uF, IRF510 as a switch gate driven by a PWM of 10v amplitude to have the maximum current rating of MOSFET) the output of the boost still at the same level of the input (no stepping up!). I'm not sure what is my mistake,by the way the output of my arduino is only one wire connected directly to the gate of the MOSFET I didn't referance the GND of the arduino to the -ve side of the system main flow. is my calculation to the inductance and the capacitance values correct?
here's a drawing of the system
Please show me what should I correct
Thanks and regards
