I'm in need of an H-Bridge capable of driving moderate-high current for motors on a small car (7A peak, 2-3A nominal, 12-14 VDC), and I'm hoping to control it with two (2) digital pins (5 VDC).
I've come up with the following controlling circuit which, based on the 2 inputs (FWD, REV), I think/hope are capable of the 4 desired states:
  1. Coast: FWD=Low, REV=Low
  2. Forward: FWD=High, REV=Low
  3. Reverse: FWD=Low, REV=High
  4. Braking: FWD=High, REV=High
So my questions are:
  • Are there any actual op-amps that will work in the circuit? I only have a few ICs in my stock (LM339N) and it doesn't work when prototyped (even with pull-ups since the outputs are OC).
  • I hope to be able to drive it using PWM (probably from an Arduino). With one pin Low and PWM on the other it should alternate between states 1-2 or states 1-3. Is this possible, and safe? Or are there timing issues at the transitions that I should concern me?
  • Ultimately, am I deluding myself or can the circuit work as I describe above, either as-is or with some tweaks?
Schematic intents: R1-R4 limit current to the MOSFETs, R5-R6 give a ~2.5V reference voltage (Vref) for comparison with the input signals. R7-R9-D2 (R8-R10-D1) shift reference voltage on pin 5 (pin 8) so Q3 (Q4) cannot be on with Q1 (Q2) and short/drain the battery. R11,R12 pull the inputs low to disable the motors when the digital inputs are disconnected.
Edit: This is for a single, hobby project at home that I expect to wire up on a simple proto-board, not even a small-run fabricated PCB.
I added emphasis on the 2nd half of the first sentence (2-wire control) - which was my primary purpose in posting: I wanted a 2-wire controller to make it impervious to software bugs.
I recommend using a pre-built motor bridge controller chip. You have lots to choose from; Digikey has 4280 options.
I say this for several reasons:
  1. Non-overlap times must be enforced, or else you'll release the magic smoke.
  2. Driving MOSFET gates through large resistors makes them sensitive to Miller turn-on.
  3. Purpose-made ICs will be generally less noise-sensitive.
  4. These purpose-made circuits often have internal charge pumps, permitting you to use the same transistor (i.e., all-NMOS) for all of your switches.
  5. In the end, it'll take less board space and be cheaper.
  • \$\begingroup\$ This is good advise. \$\endgroup\$
    – gsills
    Apr 19, 2015 at 23:20
  • \$\begingroup\$ I appreciate the suggestion, but from the Digi-Key link with: (through-hole, 10+A, full H-Bridge, brushed DC) -- the cheapest part is over $240.00. That seems rediculous, so I'll look around for other pre-fab boards (eBay, etc). Originally, my intent was more to learn.... \$\endgroup\$
    – NVRAM
    Apr 21, 2015 at 4:14
  • \$\begingroup\$ Why insist on through-hole? At the power levels you're dealing with, you don't need a heat sink; you can use the PCB for heat removal, which means surface-mount components will do fine (better). Allegro makes a fine line of motor driver products. \$\endgroup\$
    – Zulu
    Apr 21, 2015 at 17:09
  • \$\begingroup\$ @NVRAM: And if you want to build your own H-bridge, you don't want to be using comparators. A circuit built out of discrete transistors, and perhaps opto-isolators, will do much better. Or if you want to go for a bit more integration, many companies make gate driver ICs for half-bridges -- you just pick the power MOSFETs, and they handle the level shifting and non-overlap times. Additionally, Silicon Labs and Analog Devices make some great isolated gate driver products. There are many, many awesome options, but using LM339's or op-amps isn't one of them. \$\endgroup\$
    – Zulu
    Apr 21, 2015 at 17:18
