Given a general microwave amplifier circuit Amplifier circuit
For this amplifier (transistor) to be stable the the magnitude of the input and output reflection coefficient must be smaller than 1.
Stability conditions
But why? What is an intuitive explanation for why the magnitude of the input and output reflections need to be smaller than 1 for this amplifier to be stable?
Reflection coefficient is the ratio, reflected/transmitted. If your input refection coef. is >1, you could supply the amp with 1 watt and have 2 watts reflected back out to the input port. If it continues to reflect back and forth, with the magnitude increasing with each reflection, you have an oscillation.
