I am having some difficultly understanding the values described in this product sheet for the SN74AHCT14 Schmitt Trigger Inverter:
http://www.ti.com/lit/ds/symlink/sn74ahct14.pdf
Given a Vcc of 4.5V, I would like to know the following:
  • What is the lowest input voltage that would cause the trigger output to switch from low to high output?
  • What is the highest input voltage that would cause the trigger output to switch from high to low output?
And where can I find this in the product sheet?
The parameters you're looking for are VT+, "Positive-going input threshold voltage", and VT-, "Negative-going input threshold voltage". They are given in section 7.5, "Electrical Characteristics".
They have minimum and maximum values, and the appropriate boundary must be used for the given condition. The lowest voltage that would result in a guaranteed switch from low to high would be the maximum value of VT+ at 4.5V, which would be 1.9V. Likewise, the guaranteed high to low transition voltage would be 0.5V. It is possible to characterize individual parts to get more accurate values, but those are the values you can depend upon across the board.
Table 7.5 Electrical Characteristics enter image description here
Between 0.9 and 1.9 V. To guarantee switching, you'd have to be sure the input goes above 1.9 V.
Between 0.5 and 1.5 V. To guarantee switching, you'd have to be sure the input goes below 0.5 V.
