I read in documentation of AT89C51RC2, that I can make one of 5 ports to generate PWM signal if I set properly some registers. Some things I don't understand. I don't know what PCA counter is and how it behaves. There is what I came up with according to documentation.
CEX0 equ P1.3
CCAPM0 equ 0DAh
CCAP0L equ 0EAh
CCAP0H equ 0FAh
CL equ 0E9h
CCON equ 0D8h
DSEG at 30h
CSEG
    ORG 0000h
    AJMP START
START:
    MOV CCAPM0,#10000010B
    MOV CCAP0H,#0FFh
    MOV CCAP0L,#0FFh
    ORL CCON,#01000000B
MAIN:
    MOV R6,#0FFh
    DJNZ R6,$
    MOV A,01000000B
    XRL A,CCON
    JNZ null
 LJMP MAIN
 null:
    MOV CL,#0
    MOV CCON,#01000000B
    LJMP MAIN
END
I don't know which direction the CPA counter counts, whether it is needed to reset it, I don't know If I forgot to set some registers. This code doesn't work. Looks like the counter doesn't even count.
Any suggestions?
Another one register is needed to set.
CMOD equ 0D9h
I need to set mode of the PCA counter and enable Counter Overflow Interrupt. So the code goes
CEX0 equ P1.3
CCAPM0 equ 0DAh
CCAP0L equ 0EAh
CCAP0H equ 0FAh
CL equ 0E9h
CCON equ 0D8h
CMOD equ 0D9h
DSEG at 30h
CSEG
    ORG 0000h
    AJMP START
START:
    MOV SP,#70H
    SETB EA                 ; global interrupt enable
    MOV CCAP0H,#0FFh
    MOV CCAP0L,#0FFh
    ORL CCON,#01000000B
    ANL CMOD,#11111001B     ; PCA counter mode 0
    ORL CMOD,#00000001B     ; PCA counter interrupt enable
MAIN:
MOV
    R6,#0FFh        ;delay, because I use serial to change duty cycle,
    DJNZ R6,$       ;so it had time to change
    MOV A,01000000B
    XRL A,CCON
    JNZ null
 LJMP MAIN
 null:
    MOV CL,#0
    MOV CCON,#01000000B
    LJMP MAIN
END
I can see it's working with voltmeter or LED attached to port P1.3.
  • \$\begingroup\$ The CL counter and overFlow flag in CCON doesn't need to be reset in code. It works without it. \$\endgroup\$
    – user50222
    Apr 22 '15 at 20:26
