Assuming the decoder is active, the Truth table is as follows :
XZ Dec_Out HA1 HA2 a b cin F G
Sum | C Sum | C
00 1000 1 0 0 0 1 1 0 0 1
01 0100 1 0 0 0 1 1 0 0 1
10 0010 0 0 1 0 0 1 1 0 1
11 0001 0 0 1 0 0 1 1 0 1
The truth table is easy to construct :
- First determine the output of decoder corresponding to various inputs
- Next apply D0 and D1 as inputs to HA1 and D2 and D3 as inputs to HA2
- Compute their outputs and apply them to FA
Now since it was a competition problem, there has to be a short cut (which I was not able to figure out initially as well) instead of solving the truth table :P
- Two outputs of a decoder cant be simultaneously high. This means that the sum of both half adders cant be one simultaneously. Infact, output of exactly one HA HAS to be 1 always, and also that both have to give a carry of zero.
- The Xnor will always give a 1, since both carry are always zero.
- If 2 of the inputs to the Full adder are always one, the sum ie F will always be 0, while the carry ie G will always be 1.
Similar arguments hold when decoder is inactive, but this time output of both HA will be 0.
- With outputs of both half adders as zero, the XNOR is still high while A and Cin are zero
- So the input of FA consists of exactly one, which means sum ie F will always be 1 while carry ie G will always be 0.
In either case, F and G are always complements to each other.
