I was just checking a PCB design, and found these box-patterns on some of the nets. What do they mean?
  • \$\begingroup\$ I have never seen anything like that before. When you hover over it, what does the HUD show? \$\endgroup\$
    – DerStrom8
    Apr 20, 2015 at 13:53
  • \$\begingroup\$ If you zoom enough on that pattern you might see some message/label written on it \$\endgroup\$
    – m.Alin
    Apr 20, 2015 at 13:57
  • \$\begingroup\$ No, I don't see anything except the net name \$\endgroup\$
    – zud
    Apr 20, 2015 at 14:00
It looks like its related to the default Base Pattern (Checker Board) for board insight color override.
The assigned net color is displayed using small squares, leaving the default layer color also visible. (This is the default override pattern).
Related article: Customizing of Net Colors
Press F5 and the checkboard pattern goes away
