I have problems simulating the timer overflow in Atmel Studio 6. The code is for an Attiny10 and looks like below. As far as I know I set all the neccessary bits to enable the counter (which works in simulation) and the interrupt (which doesnt work in simulation).
I guess it's just a stupid mistake and I need a small hint so I would really appreciate if someone could tell me what I'm doing wrong.
;   device  attiny10
;.include   tn10def.inc
;            _____________
;           /1 °         6|
;       O--|PB0        PB3|--O RESET
;          |      t10     |
;       O--|GND        VCC|--O
;       O--|PB1        PB2|--O
;          |______________|
; defines
.def    temp    = r16
; reset / int. vecs
.org 0x0000
    rjmp    reset           ; Reset Handler
.org 0x0004
    rjmp    TIM0_OVF        ; Timer0 Overflow Handler
.org 0x000A
; reset / setup
reset:
    in      temp,   TCCR0B          ; turn timer on
    ori     temp,   (1<<CS00)
    out     TCCR0B, temp
    in      temp,   TIMSK0          ; turn overflow interrupt on
    ori     temp,   (1<<TOIE0)
    out     TIMSK0, temp
    ldi     0xff
    out     DDRB,   temp
    ldi     0x00
    out     PORTB,  temp
    ldi     temp,   0xff
    out     TCNT0H, temp
    ldi     temp,   250
    out     TCNT0L, temp
    ldi     temp,   0xff
    sei
; main loop
main:
    rjmp    main            ; while(1);
; overflow interrupt
TIM0_OVF:
    com     temp
    out     PORTB,  temp
    reti
EDIT: Solved: You cant step into/over an ISR. (Thx to Golaž)
If you havent got a compiler error when trying to compile the exact code you posted, you have a bigger problem.
Your code is working fine (ignoring the fact you missed out the register names in your 3rd block under reset label). However I would make some changes:
;   device  attiny10
;            _____________
;           /1 °         6|
;          |      t10     |
;       O--|GND        VCC|--O
;       O--|PB1        PB2|--O
;          |______________|
; defines
.def    temp    = r16
; reset / int. vecs
.org 0x0000
; Replace : .org 0x0004 with:
.org OVF0addr
; Replace: .org 0x000A with:
.org INT_VECTORS_SIZE ; End of vector table.
; reset / setup
reset:
    ; Initialize stack:
    ldi r16, HIGH(RAMEND)
    out SPH, r16
    ldi r16, LOW(RAMEND)
    out SPL, r16
    ori     temp,   (1<<CS00)
    out     TCCR0B, temp
    out     TIMSK0, temp
    ; You forgot to specify the regsiter here:
    ldi     temp,   0xff
    out     DDRB,   temp
    ldi     temp,   0x00
    out     PORTB,  temp
    ldi     temp,   0xff
    out     TCNT0H, temp
    ldi     temp,   250
    out     TCNT0L, temp
    ldi     temp,   0xff
    sei
; main loop
main:
TIM0_OVF:
    com     temp
    out     PORTB,  temp
    reti
You can find the include files for devices and all their specifics (such as OVF0addr, INT_VECTORS_SIZE, RAMEND, ...) in:
C:\Program Files (x86)\Atmel\Atmel Toolchain\AVRAssembler\Native\2.1.1117\avrassembler\include
I am not sure what your exact goal was here, when you've setted TCNT0 registers you've only set its value for one (current) cycle, when the timer would reach its maximum value it will restart from 0.
What was your goal with TIM0_OVF ISR I am not sure.
Stack is needed for the MCU to know which address to return to after the call to subfunction or ISR have been executed.
  • \$\begingroup\$ Well the stack pointer is initialized to RAMEND by default (by the simulator) it doesnt change a thing with or without initializing it manually. I want to have a timebase. Setting TCNT0 to that value make it overflowing in some tickes and i dont have to press F11 ~60000 times to see it overflowing. I knot that the timer overflows from MAX to 0 but when that happens it sould execute the overflow ISR but it doesnt and thats the problem. Eventhough without initialized stackpointer the simulator should at least enter the ISR but it doesnt. \$\endgroup\$
    – milkpirate
    Apr 20, 2015 at 16:13
  • \$\begingroup\$ @user3097432 How did you come to the conclusion, that the ISR doesnt get fired? Did you put a brakepoint in there...? \$\endgroup\$
    – Golaž
    Apr 20, 2015 at 16:18
  • \$\begingroup\$ @user3097432 You dont have to manually tap F11 60000 times, just put a brakepoint along side one of the instructions inside ISR and click run. Also, if nothing more manually setting stack pointer ensures better portabillity. \$\endgroup\$
    – Golaž
    Apr 20, 2015 at 16:26
  • \$\begingroup\$ I know I dont have to tab F11 60000 times if I preset the timer register close to the MAX which I did. I can tell its not entering the ISR because I can step into (F11-key) and watch all the registers and the actual program counter position. I dont let the simulation run in free mode I let it run step by step so I let the program run op-code by op-code. And the code in the ISR, which is supposed to invert the value of PORTB, doesnt change PORTB. \$\endgroup\$
    – milkpirate
  • \$\begingroup\$ @user3097432 Please do as described above. \$\endgroup\$
    – Golaž
    Apr 20, 2015 at 16:27
