In the circuit below, where would I place an audio taper potentiometer to modulate the output volume level? Which of the resistors should get replaced with the pot and why?
If understand correctly, I should place the pot between the input decoupling capacitor and the buffer amp is this correct? Additionally, this circuit was designed for +-12V, if I am only capable of providing half of the +-12V, around +-6.2V, what effects will I observe, will the amp still function, just at a lower output?
