I wish to update the software running on a node having a ARM Cortex M4 MCU.
to do so, I understand I will have to run a bootloader in my TI ARM Cortex M4 development board that can receive a binary file over-the-air and program certain section of flash. I understand the functionality of receiving binary file over-the-air will have to be added to this bootloader.
This sounds all correct but I do not understand how this can be achieved. How is it possible that I program parts of the flash in the MCU by the same MCU itself?
Do I need additional hardware to do update software running on my node? All I want to do it to update the software running on my node over-the-air. A bin fine can be downloaded over HSDPA. For easy testing I can do this over Ethernet.
I would so much appreciate if someone can elaborate how this process is done in a more detailed format for me to understand the procedure. Thank you very much.
