I want to built solar panel system and i rather to buy system parts and assemble them by myself, but i don't know the calculation :
1- How to calculate what kind of solar panel(How many Watt and Ampere) is suitable for my location ? some of theme is define by watt and other define by Amp and Volt,so i get confuse.
(I found gaisma.com but i don't know how to use it in calculation, we have 12 hour sunshine).
2- I know i can use 12.v car battery but How many of theme i can use compare to my panel (Is there any formula to calculate that)?
3- How to i find suitable Controllers and Inverters for battery (volt & amps) ? (I heard if i don't use proper Inverter, it might explode).
PS : Big vendors like ebay and alibaba services is not available in my country(Iraq) as i know,so if you be more general about the range of option which i can use, i will be appreciated.
PS2 : I don't want to apply it in the facility power grid, i just want it to charge the batteries and inverter give me an output.
  • \$\begingroup\$ Local norms will apply to the inverter. Check with your power company. Ebay and Alibaba are not particularly good places to buy these things because you often can't verify these specific specs. Also if you state "big vendors like ebay and alibaba services is not available in our country", it might help if you told us what "our country" is. \$\endgroup\$
    – jippie
    Apr 22, 2015 at 5:47
  • \$\begingroup\$ @Jodes I don't want to design whole system,I want to buy component which work together.I found a range of option so i get confused. \$\endgroup\$
    – zokit
  • \$\begingroup\$ @jippie I've updated the question. \$\endgroup\$
    – zokit
    Apr 22, 2015 at 6:01
  • \$\begingroup\$ You do not have 12 hour sun EXCEPT if you live inside the polar circles. SSH = sunshine hours = kWh/m^2/day in graph 4 1st line. || Gaisma Bagdad - 4th graph top line = SSH = equvalent full sunshine hours per day. \$\endgroup\$
    – Russell McMahon
    Apr 22, 2015 at 13:55
One formula you will use often is:
Power (Watts) = Voltage (Volts) x Current (Amps).
The more power, the more energy it produces. If only amps and volts are specified, you can calculate the power from that by multiplying them.
The rating of a solar panel in Watts will be the maximum for full sunshine. So when it is cloudy, the power produced will drop significantly, down to approximately 10-20%.
You can use any battery, as long as you have a circuit which controls the charging of the battery. However, this circuit needs to be compatible with your battery and the solar panel. The larger the battery, the more energy it can store, for example to store energy from sunny days so it's available on cloudy days or at night. Too small a battery and you might not even have enough power at night.
I will go through one example for you, so you can follow the process for whatever system you want to use.
First, decide how much electricity you will use. Say you want to run a TV from it, for 4 hours a day. And say the TV uses 100 watts, and runs off 230V.
The total energy your TV will use per day is 4 x 100 = 400 watt-hours.
And say you have 12 hours of sunshine every day. To get 400 watt-hours, you would need a panel that has a power of 400 / 12 = 33.3 Watts. This could, for example, be a solar panel that produces 1 amp at 33.3V, or 66.6V at 0.5A, or whatever, as long as amps x volts is greater than or equal to 33.3W.
If you want to use the TV at night, you will want the battery to store 400 watt-hours. So if you use a 6V battery, it must have a usable capacity of 400 / 6 = 66.6Ah (Amp-hours). Or if you use a 24V battery, it must have a usable capacity of 400 / 24 = 16.6Ah. If you use a car battery, be aware that most car batteries need to maintain a charge of between 50% and 75% if they are to have a long life. So only a quarter of its stated amp-hour capacity can be used. So say you buy a 100Ah battery, you will only be able to use 25 amp-hours! It would be more cost-effective if you buy a so-called "deep cycle" battery, so you can typically use more like 80% of its capacity without causing premature ageing.
And say your solar panel produces 48V. You will need a system which solar panel controller that can charge a 6v, 67Ah battery from a 48v, 34W solar panel. This will be hard to find: you may need to start with the controller, then buy a solar panel and battery accordingly. The "controller" is made up of two parts, and you may want/need to buy them separately: The first part is a voltage converter, which takes the voltage of the solar panel, and converts it into a voltage for charging the battery. Then the battery charger is essentially a circuit that uses the supply from the voltage converter to charge the battery without overcharging it.
Finally you will need an inverter which produces at least 100 Watts, from a 6v supply, to 230V AC.
